Re: 3.23 and 727 speedo gear [Re: RapidRobert] #563242
12/26/09 07:17 PM
12/26/09 07:17 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Like I said earlier a 235/60-17 tire should be 28.3 tall and per the chart you would use a 30 tooth gear...
Re: 3.23 and 727 speedo gear [Re: 1_WILD_RT] #563243
12/26/09 08:21 PM
12/26/09 08:21 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
sorry guys.....the tire size is 225 55 17....so what gear would that be?
Re: 3.23 and 727 speedo gear [Re: roy2345] #563244
12/26/09 09:13 PM
12/26/09 09:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Measure the tire as instructed then look at the chart posted above. It's not rocket science. You just have to do a little work for yourself.
Re: 3.23 and 727 speedo gear [Re: 1_WILD_RT] #563245
12/26/09 10:10 PM
12/26/09 10:10 PM
IMGTX Offline
IMGTX  Offline
Clocking is easy.
It isn't very clear in that pic but under the arrow at the 6'oclock position there is a dot cast into the extension housing. That dot roughly lines up with the numbers that represent your gear.
i.e. if you have a #30 gear line the numbers 26-31 on the adapter to the dot.
Install the clamp with the tabs in the slots and your done.
I agree it is easy... But not knowing about it would be bad...
Your right. I though I was helping but you are a much faster typer....
Re: 3.23 and 727 speedo gear [Re: roy2345] #563246
12/26/09 10:14 PM
12/26/09 10:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
26.8 = 32 teeth
Re: 3.23 and 727 speedo gear [Re: 1_WILD_RT] #563247
12/26/09 10:52 PM
12/26/09 10:52 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
what I came up with 2...Thanks
