Post deleted by Defbob
[Re: Tommy383]
#562555
12/26/09 12:47 AM
12/26/09 12:47 AM
Re: tremec 6-speed
#562556
12/26/09 01:16 AM
12/26/09 01:16 AM
Triple Threat
Renton Washington
How much does the CTS weigh Fred?
Re: tremec 6-speed
[Re: The Cuda Guy]
#562560
12/26/09 04:24 AM
12/26/09 04:24 AM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
I am in the middle of doing this. Have matched to my 572 Hemi. The T6060 is the same as the T56 Magnum. Quicktime make a bellhousing P/N RM6077. This trans is rated to 700/700, but investigation shows it will certainly handle more so I am prepared to take the risk as mine will not be seeing continuous load like that (just bursts) Have LOADS of information & pic's, PM me. Darren
-------------------------------- Darren Beale Keith Black Racing Engines®
Re: tremec 6-speed
[Re: Keith Black®]
#562561
12/26/09 03:27 PM
12/26/09 03:27 PM
Posts: 576 Somewhere Over the Hill
Mr. Dodge
If your looking for a trans for your car look at http://www.americanpowertrain.com/ I have on going in a 1000 hp Hemi Coronet R/T and they guarantee it up to 1300 to 1400 ft lbs torque.
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison)
69 Hemi Coronet R/T
70 456 Dart Swinger
Re: tremec 6-speed
[Re: Mr. Dodge]
#562562
12/26/09 06:03 PM
12/26/09 06:03 PM
Keith Black®
QLD Australia
B Body install of T6060/T56Magnum:
Re: tremec 6-speed
[Re: Keith Black®]
#562563
12/26/09 06:05 PM
12/26/09 06:05 PM
Keith Black®
QLD Australia
Bellhousing RM6077 (needed minor modification) Use GM/Tremec T6060/T56 as input shaft length is correct.:
Re: tremec 6-speed
[Re: Keith Black®]
#562564
12/26/09 06:16 PM
12/26/09 06:16 PM
Posts: 22,722 Bitopia
jcc
Bitopia
Have any pics of the TB rear crossmember replacement yet?
Re: tremec 6-speed
[Re: jcc]
#562565
12/26/09 06:40 PM
12/26/09 06:40 PM
Keith Black®
QLD Australia
We're fabricating that right now.
Re: tremec 6-speed
[Re: Tommy383]
#562567
12/26/09 07:07 PM
12/26/09 07:07 PM
Keith Black®
QLD Australia
Yes, with the RM6077 bellhousing you have to use the Tremec TUET7277 (T56Magnum), or the other GM one (can't remember the PN), they have the correct input shaft length. With the bellhousing you need to use a 130th flywheel.
have just installed the Unlawful Racing 4-link rear too... (it's awesome.. will post another link on this).
Re: tremec 6-speed
[Re: Keith Black®]
#562568
12/26/09 07:10 PM
12/26/09 07:10 PM
Keith Black®
QLD Australia
viewed from the back of the car..
Re: tremec 6-speed
[Re: hemidup]
#562572
12/27/09 12:01 AM
12/27/09 12:01 AM
Triple Threat
Renton Washington
So the dodge trannys wont work due to the input length? The factory bellhousings should bolt right up to an A engine being the bolt pattern is the same as a new Hemi...
