Page 8 of 8 1 2 3 4 5 6 7 8
Re: Engine pictures [Re: rickma] #561492
01/01/10 05:36 PM
01/01/10 05:36 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Engine pictures [Re: Dartsport540] #561493
01/01/10 06:03 PM
01/01/10 06:03 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
mine
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Engine pictures [Re: go green] #561494
01/01/10 06:10 PM
01/01/10 06:10 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
340
6.50 @105.26
Re: Engine pictures [Re: Kindafast] #561495
01/01/10 06:15 PM
01/01/10 06:15 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Hemi
Re: Engine pictures [Re: B G Racing] #561496
01/01/10 06:22 PM
01/01/10 06:22 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Hemi-2
Re: Engine pictures [Re: B G Racing] #561497
01/01/10 06:30 PM
01/01/10 06:30 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Peddler Hemi
Re: Engine pictures [Re: B G Racing] #561498
01/01/10 06:38 PM
01/01/10 06:38 PM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
new PB at a 12.57 110mph using 105 octane(without using the gas)
312 cubes of all Australian designed engine
zero deck hight & .070 off the heads, 11 to 1 comp
hyd flat tappet .495" 240@ 50 on a 109l/s
flat tops with no valve releifs
early heads with a wild port job (buy a mopar head specilist)
MSD street fire HEI with updated module & coil
M40 transmission (all aussie)
3500 stall, manual valve body
salisbury rear end (all Aussie)
4.44 gears spool with 26"x8 M&H treaded tyres
2970lb vehicle
could see 11s with the gas but trans needs more work now
Re: Engine pictures [Re: SG duster] #561499
01/01/10 06:51 PM
01/01/10 06:51 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
my junk
Re: Engine pictures [Re: SG duster] #561500
01/01/10 07:10 PM
01/01/10 07:10 PM
SG duster Offline
SG duster  Offline
448ci 12.8 to 1 flat tappet 260ish
Re: Engine pictures [Re: SG duster] #561501
01/01/10 08:06 PM
01/01/10 08:06 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
My 493". Not finished in this pic, but is now.
If you like drag racing, support your local track.
Re: Engine pictures [Re: CHAPPER] #561502
01/01/10 09:28 PM
01/01/10 09:28 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
Mine is just a junk yard 360, but it works well for a little street/strip Valiant.
Re: Engine pictures [Re: Valiant_Showoff] #561503
01/01/10 09:29 PM
01/01/10 09:29 PM
Alliance, Ohio
V
V
Alliance, Ohio
Installed:
Re: Engine pictures [Re: Valiant_Showoff] #561504
01/26/10 10:42 PM
01/26/10 10:42 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
Just a little late for christmas but I was bored
It is shinee like a christmas bulb
