Re: 11.75" rotors which cars ?
[Re: MadMatt]
#560531
12/26/09 08:18 AM
12/26/09 08:18 AM
Posts: 340 Vitoria, Spain
Coke
Vitoria, Spain
Are you happy with that setup? I'm gathering parts for the swap. I have the spindles and finally tracked down a good set of Viper calipers today at a reasonable price. What size wheels are you running? I'm hoping and praying it will fit inside my 15" Halibrand 5-spokes.
Well, i have not driven the car very much ,it passed the Brake test in the technical inspection,but i belive that they should to brake more. I have manual brakes now but they definetively need power boost,so i will mount a Hidro Boost system when i finish the engine. The company that builds the adapters for the Viper Calipers suggests manual brakes but i desagree . I do not recall how much fluid pressure arrives to the caliper,but i,m pretty sure that they need more.
About the wheels they are 15" Weld Pro Star. The caliper rubbed a little on the spokes so i put a couple of washers between the calipers and the bolts just for keeping the caliper a bit further from the wheel .Thats how i solved the trouble.
I have a list with all the parts required in some place(That i should to looking for). If you need help, send to me a PM.
Regards
[Re: Coke]
#560532
12/26/09 09:11 AM
12/26/09 09:11 AM
Posts: 62 New Brunswick
Unfair Advantage
New Brunswick
Even though the rotors are thicker on the C bodies and trucks are the caliper adapters the same as the b bodies ??
[Re: Unfair Advantage]
#560533
12/26/09 10:59 AM
12/26/09 10:59 AM
Posts: 27,483 So Cal
autoxcuda
So Cal
No, the C-body adapters are different. They will not meet the dimensional specs outlined in the www.moparaction.com article.
[Re: Coke]
#560534
12/26/09 11:08 AM
12/26/09 11:08 AM
autoxcuda
So Cal
A power booster just assists with pedal pressure. It does not increase line pressure to the caliper.
MadMatt ran into a similar situation and he changed the master cylinder diameter.
[Re: Husker1]
#560538
12/26/09 02:52 PM
12/26/09 02:52 PM
Posts: 4,760 Florida
BDW
i am getting ready to do this swap and was wondering if all of the 11.75 rotors are the same? I know if you read the "disc-0-tech" article it says to get the HD police rotors. As far as i can tell there is only one style of 11.75 rotor. i was going to purchase the (NB 4885579) premium part from NAPA, the picture shows the extra ribbing on the inner bearing race like the article states for the police rotor. Is this the right rotor? i looked it up under '76 cordoba, which is what i got my caliper adapters off of. if this is the right one i guess keep ordering them until i get two made in usa.
Pretty sure the article referes to the adapter, not the rotor, as being HD police versions. The HD adapter has more ribbing.
[Re: BDW]
#560540
12/26/09 03:34 PM
12/26/09 03:34 PM
Posts: 8,914 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
No, it specifically refers to the rotors. It also makes mention of a heavy duty adapter.
[Re: broncobra]
#560542
12/26/09 04:34 PM
12/26/09 04:34 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Wow, I posted a big answer and guess I didn't hit the right button. Anyway, If you buy replacement rotors from NAPA for the 1981 Cordoba, be aware that they sell a Blue and a Gold standard. One's cheap, the other higher. It doesn't matter on the rotors, you can still get either Chinese junk or Canadian goodness. It all boils down to what the warehouse has on hand for your area. My NAPA dealer (that I've known for years) told me he can't special order one or the other and kinda got in a huff when I kept ordering and sending back the China junk. They are that bad. Set them side by side and you can see and feel the difference. Specify the Gold and don't take the China crap for anything.I sent many back until I had a usable set for immediate bolt on, and an extra set for future brake replacement repair.
FWIW, an '81 cordoba is a J body, and only came with the smaller 10.875" rotor from the factory.
[Re: @#$%&*!]
#560545
12/26/09 11:46 PM
12/26/09 11:46 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
I found the pin type adapters on a 77 Grand Fury. Big 11.75 cop car discs on a 318 car...
Isn't the 77 Gran Fury a C-body?
My mistake, it was a 77 B-Body Fury like this one:
The Fury name has been tossed around so much that I loose track sometimes.
