516 heads #560236
12/22/09 08:40 PM
12/22/09 08:40 PM
Temecula, Ca.
Z
zzyzxpat Offline OP
zzyzxpat  Offline OP
Z
Temecula, Ca.
I am putting together an original 361, and want to keep it all original. I know that 440s,383s are a better way to go per dollar spent, but I am a little different sometimes. The heads have had 1.74 exhaust valves installed and all new valves. I am going to run a Lunati 60304, .513-.533. The proper springs are there. My question would be on porting. I am going to do it myself and am asking for advise from those who have knowledge in this area. Please don't tell me to change to a different head. This 361 will be stroked to 450 but look completely stock and is going in a numbers car. Thanks in advance.
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 516 heads [Re: zzyzxpat] #560237
12/22/09 09:31 PM
12/22/09 09:31 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I would pm fast68 on the board here. here is a write up he did on the 516-V-906 head.Very good write up Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 516 heads [Re: mopar65] #560238
12/22/09 11:05 PM
12/22/09 11:05 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Check out the Tech Archive .
Re: 516 heads [Re: camdog440] #560239
12/22/09 11:36 PM
12/22/09 11:36 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Get the MP templates and have at it.
Re: 516 heads [Re: camdog440] #560240
12/22/09 11:39 PM
12/22/09 11:39 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Sonic check them first.
A friend decided to take the cheap way out and port a couple of these for his NSS car. He ground them thin and cracked not one pair, not two pair, but at least three that he has admitted to. He runs Max Wedge heads now.
Re: 516 heads [Re: zzyzxpat] #560241
12/22/09 11:58 PM
12/22/09 11:58 PM
United States
STLDuster Offline
STLDuster  Offline
United States
Not a bad head with the bigger valves and some porting
I love mine!
"No great genius has ever existed without some touch of madness." - Aristotle
Re: 516 heads [Re: STLDuster] #560242
12/23/09 12:08 AM
12/23/09 12:08 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I love mine!
as long as you don't spend a bunch of $$$ on them.
Re: 516 heads [Re: KillerBee] #560243
12/23/09 01:12 AM
12/23/09 01:12 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I don't want to sound like a jerk, but if we are being picky about numbers, isn't a numbers 361 not possible?
Only date coded would be possible, since 361's were prior to block vin stamping.
That said if it is beleived to be the original motor for the car, does it make any sense to stroke it, and cam it up, and the hope that the block doesn't get a window in it while bagging it?
Sorry I couldn't resist asking. Not trying to start a peeing match or anything.
In any case, back to the thread, I think a good port job will work with 516's, and 450" motor. Rpms will be a little more limited than with some of the newer heads since the intake runners are a smaller volume, but should still work.
Re: 516 heads [Re: zzyzxpat] #560244
12/23/09 08:03 AM
12/23/09 08:03 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The ones I had on my 440 had 2.14 and 1/81 stainless valves in them.They had been ported some also.I pullerd over 6500 all the time with them/They are on the kids 413 now.Porting like said you have to be careful.Its not too hard when doing them to hit water.Rocky
Chrysler Firepower
Re: 516 heads [Re: therocks] #560245
12/23/09 09:05 AM
12/23/09 09:05 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I've made 450/490 on them, a med size hydraulic cam, and pump fuel. But those were not template ported... They went a bit beyond that. I think for the cash the Source heads would be the best fit in terms of cost, effort, sneakiest and most stock appearing head for it. If you want to use the 516s be careful as bigger is not always better and understand there will be power and rpm limits as a result of a long stroke and average at best port design/shape.
Re: 516 heads [Re: dave571] #560246
12/23/09 09:22 AM
12/23/09 09:22 AM
Temecula, Ca.
Z
zzyzxpat Offline OP
zzyzxpat  Offline OP
Z
Temecula, Ca.
You are right. Just trying to do something a little different. It is a 66 Coronet. No way to verify that it is original ( it is. ) If done right and kept under 5000rpms, I think it will stay together. I have no experience with 516s, so the reason for my question. I have heard about hitting water with these. Thanks for your input. Pat
Re: 516 heads [Re: zzyzxpat] #560247
12/23/09 11:40 AM
12/23/09 11:40 AM
Puyallup, WA
Puyallup, WA
I've never heard of a 450" 361 combo. What Crank are we talking about? Without knowing anything about the specifics, my first reaction is that it sounds like a an awful short piston, for a street motor. (???) I don't know that I'd feel good about going this route with a #'s correct block (???). A 3.75 stroke should get you into the 420" neighborhood (just off the top of my head), and would still be a reliable street motor.
Re: 516 heads [Re: StealthWedge67] #560248
12/23/09 12:05 PM
12/23/09 12:05 PM
Temecula, Ca.
Z
zzyzxpat Offline OP
zzyzxpat  Offline OP
Z
Temecula, Ca.
My formula was 4.155 bore,4.250 stroke,6.535 rods, with a compression height of 1.320.
Open to suggestions if you think that is not the best for a street motor.
4.250 stroke,6.535 rod,1.320 compression height.
Re: 516 heads [Re: zzyzxpat] #560249
09/24/13 01:00 PM
09/24/13 01:00 PM
dogdays Offline
dogdays  Offline
That combo is done all the time with a larger bore, like in a 383 or 400 block, so the compression height shouldn't be an issue. Make sure the connecting rod doesn't run into the end of the bore somewhere around mid-stroke.
I applaud you for going into new waters, 361s are giveaway engines. I actually turned down one several years ago, and my motto is, "A man can't have too many pieces of cast iron aging in his back yard."
Your proposed engine is basically an Olds 455 with a little shorter rod and shorter comp height.
Dwayne Porter, aka Fast68, did a set of 516s as mentioned above. He is a really good source even if you are going to do the work yourself. I don't think he'll worry about the competition!
If I was your tech adviser I'd steer you directly to the Stealth heads. Out of the box they will be worth 100 hp over a home ported set of 516s, and they will have an advantage from idle to redline.
But either way it will honk at low rpm. You'd better buy a set of 2.76s for your 8 3/4!
R.
Re: 516 heads [Re: dogdays] #560250
09/24/13 02:13 PM
09/24/13 02:13 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
And better oiling system. And better heads. And better block.
Re: 516 heads [Re: zzyzxpat] #560251
09/24/13 03:33 PM
09/24/13 03:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
413 and 361 have the same stock bore, 4.180 I beleive Not 4.155
Re: 516 heads [Re: Cab_Burge] #560252
09/24/13 04:55 PM
09/24/13 04:55 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
361 stock is 4.125 so .030 over puts him at 4.155.
Kevin
Re: 516 heads [Re: Twostick] #560253
09/24/13 06:13 PM
09/24/13 06:13 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
The 452 heads have induction hardened exhaust seats, if you're gonna run pump gas.
Just sayin................
Re: 516 heads [Re: dogdays] #560254
09/24/13 06:36 PM
09/24/13 06:36 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
OOTB! 100 HP??
I'd like to see some real world dyno data on that. Must be bone stock 516's. A fare comparison would be some MP template ported 516's with the same size valves, fresh valve job, good guides.
Re: 516 heads [Re: Dean_Kuzluzski] #560255
09/25/13 01:13 PM
09/25/13 01:13 PM
dogdays Offline
dogdays  Offline
My point about the Olds 455 was that this combo has already been OEM and to give some idea about what kind of engine to expect. I grew up with a 455 and for tire smoking torque it was hard to beat. With the stock 2.56 rear end it'd cruise effortlessly at 90, to boot!
The 100 hp? Comparing stock 516 heads with a decent valve job with out-of-the-box Stealths there is at least a 50 cfm advantage going to the stealths. With a 450+ cubic inch engine under them, the Stealths WILL make 100 hp more than the stock 516s.
And if you want to spend $1500 to get the 516s to equal the Stealths in terms of flow, don't come crying when they crack and turn into doorstops!
R.
