Page 2 of 3 1 2 3
Re: Tips on restoring rim blow wheels [Re: Quikshft] #559291
12/27/09 05:43 PM
12/27/09 05:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
One other thing I noticed is that the stainless trim bands are 'exposed' on original wheels, not buried under several applications of clear coat
...I generally like to see any Stainless Steel bands exposed, but if you don't have a band, and you substitute the chrome tape, or wish to color match the outerband to the car's color,....usually it's best to bury the tape under a few coats of clear, otherwise you'll palm it off in use
Re: Tips on restoring rim blow wheels [Re: DAYCLONA] #559292
12/29/09 12:37 AM
12/29/09 12:37 AM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
Unlike the rimblow which has a tape stripe, the 68-70 A and B body woodgrain wheels used a stainless steel band on the inner and outer perimeter of the rim. If it gets scratched, it can be sanded out with 400 grit sandpaper and will look like new again. Also, with it being stainless steel, you don't have to worry about it rusting or tarnishing so you don't have to clear over it unless that's just what you want to do. I like the bands slightly exposed as well.
Now, to keep the DIY guys motivated, here's before and after shots of a 70 B body woodgrain we recently had in the shop.
Before
Re: Tips on restoring rim blow wheels [Re: plumbeeper] #559293
12/29/09 12:40 AM
12/29/09 12:40 AM
plumbeeper Offline
plumbeeper  Offline
After
Re: Tips on restoring rim blow wheels [Re: plumbeeper] #559294
12/29/09 07:57 PM
12/29/09 07:57 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Dave, Mike, Jeff,
You guys have been very helpful. Hats off to Doug Lepak for offering some of his tips too.
1st time DIY'r so I started at it last night. Not a rimblow but a 69 A body. The wheel had typical surface cracks and 3 good size 1/2" splits, loose bands, the usual for a 40 year old wheel. Started grinding the top of the rim to remove material and looks like I see how ma mopar made these wheels.
Looks like they molded a base layer around the main rim, then glued the bottom (grip portion)onto the molded base. This portion has the recessed areas to accept the ss bands. Once the bands were set on place, the top layer was glued to the molded base which sandwiched the ss bands. These top and bottom layers are only approx. 1/8" thick but are curved on the inside the shape of the molded base.
I removed the top layer by slipping a small screwdriver between the top layer and molded base and it just fell apart in pieces, totally weathered and dryroted.
Anybody repoping just the top and bottom layers? The resto would be so much easier.
1st pic
Re: Tips on restoring rim blow wheels [Re: Pntastar69] #559295
12/29/09 07:59 PM
12/29/09 07:59 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Top layer removed
Re: Tips on restoring rim blow wheels [Re: Pntastar69] #559296
12/29/09 08:01 PM
12/29/09 08:01 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
SS band channel on lower portion
Re: Tips on restoring rim blow wheels [Re: Pntastar69] #559297
12/29/09 08:03 PM
12/29/09 08:03 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Underside of top layer
Re: Tips on restoring rim blow wheels [Re: Pntastar69] #559298
12/29/09 08:04 PM
12/29/09 08:04 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Top layer in pieces.
Now the fun begins.
Re: Tips on restoring rim blow wheels [Re: Pntastar69] #559299
12/29/09 08:04 PM
12/29/09 08:04 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Last 1, the ss bands
Re: Tips on restoring rim blow wheels [Re: Pntastar69] #559300
12/30/09 12:04 AM
12/30/09 12:04 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Wow great pics Mark. That makes it easy to see how they were constructed and it sure seems like it would be a simple item to repop. Be nice if you could simply disassemle and old wheel like yours or mine which had decent spokes, and just snap on an new exterior portion.
Re: Tips on restoring rim blow wheels [Re: plumbeeper] #559301
12/30/09 11:33 AM
12/30/09 11:33 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I am loving this post. I have a couple rimblows I'l looking at fixing. Thank you to all that have posted some great info.
Re: Tips on restoring rim blow wheels [Re: migsBIG] #559302
12/31/09 09:31 PM
12/31/09 09:31 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
good luck with that wheel...
Re: Tips on restoring rim blow wheels [Re: AARCONV] #559303
01/01/10 10:28 AM
01/01/10 10:28 AM
WNY
slimert Offline
slimert  Offline
WNY
Great info. Wish it was posted a few years ago... would have saved me some $$!
I have done a few rimblow wheels and it gets easier like anything else with practice.
Thanks for sharing Mike and Dave.
Mike.
Re: Tips on restoring rim blow wheels [Re: slimert] #559304
01/02/10 06:20 PM
01/02/10 06:20 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Hey guys, just thought I'd post some progress shots. Been on vacation this week and have been working on my wheel here and there. I spent a significant amount of time today and yesterday cutting some grain into my rim. I think it's going to be good enough for me, I'm satisfied. Have not shot black paint into the cuts to make the figure pop, that is coming up I guess.
Re: Tips on restoring rim blow wheels [Re: Quikshft] #559305
01/02/10 10:16 PM
01/02/10 10:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Wow!.....big improvement Jeff, looks really nice! really does
Mike
Re: Tips on restoring rim blow wheels [Re: DAYCLONA] #559306
01/03/10 12:46 AM
01/03/10 12:46 AM
Virginia, United States
CoronetRTguy Offline
Wow very nice job done to all you guys. This needs to be a sticky for sure.
I never thought about trying a wheel myself but it looks like fun and one that takes a lot of time and skill.
Very good post book marking it myself.
Re: Tips on restoring rim blow wheels [Re: CoronetRTguy] #559307
01/03/10 10:48 AM
01/03/10 10:48 AM
P
Pntastar69 Offline
Pntastar69  Offline
P
Great work Jeff
Re: Tips on restoring rim blow wheels [Re: Pntastar69] #559308
01/04/10 11:27 AM
01/04/10 11:27 AM
ME
79machocharger Offline OP
ME
Quikshft your grain looks great . What method did you end up using for putting in the grain?
Re: Tips on restoring rim blow wheels [Re: 79machocharger] #559309
01/04/10 04:32 PM
01/04/10 04:32 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
I used/am using a very high tech tool for this work...a broken off hacksaw blade. I just ground the end to leave one complete tooth exposed. I also ground the sides of the blade to make the tooth a little bit narrower so the cuts weren't un-naturally large. Actually now, and a lesson here from experience, I should have used two different blades to get a little bit of dis-uniformity to the width of the grain cuts. Still, I'm satisfied and unless I get a little too picky I will probably leave it as is.
Re: Tips on restoring rim blow wheels [Re: Quikshft] #559310
04/28/11 01:47 PM
04/28/11 01:47 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Resurrected an old post. Here is where I'm at w/my wheel. Took some time, a lot of time. I went w/powder coat for the spokes and decided to go w/satin black for the rim w/out the grain. It's all in primer and at the shop for paint. Hope to have it back next week.
Page 2 of 3 1 2 3
