B1 TS Heads Info #558821
12/20/09 06:44 PM
12/20/09 06:44 PM
Salt Lake City
camastomcat Offline OP
Salt Lake City
I am considering upgrading from B1 originals, and have heard good and bad about these heads. Scott Koffel has been a good guy to deal with and I would rather buy from him, but would like to know the scoop from guys that use them. I heard they have terrible valve train geometry. True or faulse? Also, will they fit a on wedge block? Do they need drain back lines, dedicated rockers, who makes them, clearancing of the pushrod holes, and mostly, what do they flow, I heard as much as 530CFM? Also, what does it cost to convert? Any advise would be appreciated. Special headers, or do B1's work?
Re: B1 TS Heads Info [Re: camastomcat] #558822
12/20/09 06:55 PM
12/20/09 06:55 PM
SC304 Offline
SC304  Offline
Wedge Block ? NO they have a 12 oclock stud like a Hemi.
Drain Backs? Not Really
Original Headers? No not without some trick Adaptor Plates.
Valve Train ? You need to know what you are doing as you would with any HP Application.Jesel makes all the rocker gear in any ratio you want. the valve train is set up on stands like the BBC.
Pushrods require some work like tubes thru ports etc To get any size to run the required spring pressues.
I have heard 530 CFM but have not seen any. MIne flow under 520.
Scott and Dave can hook you up. It is there head after all. OR i can save you alot of headache!!!
Re: B1 TS Heads Info [Re: SC304] #558823
12/20/09 07:12 PM
12/20/09 07:12 PM
Mike, what oiling system are you running?I'm in the market for one that will fit a stock early b body K frame? not sure if i'm going to a wet vac system or dry sump, any recommendations?
Re: B1 TS Heads Info #558824
12/20/09 07:59 PM
12/20/09 07:59 PM
SC304 Offline
SC304  Offline
As you can see mine was buit with the dry sump.
It was for a Top Dragster so there were no worries of a cross member.
I suspect you could run the Billet Dry sump unit i have seen that is driven by the conventional distributor intermediate shaft ?
Re: B1 TS Heads Info [Re: SC304] #558825
12/20/09 08:13 PM
12/20/09 08:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I love b1 stuff but my next stop will be Predator...Unless there is a SMOKING deal to be had on a TS set up.
Re: B1 TS Heads Info [Re: Al_Alguire] #558826
12/20/09 08:54 PM
12/20/09 08:54 PM
Salt Lake City
Salt Lake City
I heard they had trouble with those too. Something about knocking the mains out of them.
Re: B1 TS Heads Info [Re: camastomcat] #558827
12/20/09 09:12 PM
12/20/09 09:12 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
those heads are outrageous
Re: B1 TS Heads Info [Re: Al_Alguire] #558828
12/20/09 09:19 PM
12/20/09 09:19 PM
AL,how's 1296 hp on this b1 ts setup.want a deal?
i'm looking to race Hemi SS/AH. we are never satisfied.
Re: B1 TS Heads Info [Re: camastomcat] #558829
12/20/09 10:05 PM
12/20/09 10:05 PM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
How does a cylinder head "knock" main bearings out???
Anyway there are a bunch of Predator headed engines that see 8000+ rpms and over 250 passes a year.
I shift mine at 9200 and the bearings looked new when it was freshened.
Call me if you have any questions about Predator heads.I will give you the straight story and not a sales pitch.
BTW,I have a set of wedge pattern heads the flow 545 at .900
if flow numbers are what your comparing.
Re: B1 TS Heads Info [Re: gillman34] #558830
12/20/09 10:38 PM
12/20/09 10:38 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I have had no issues at all with my heads and turn them to 8400 RPM and make over 2200 HP. I Believe I found out my head gasket problem ( it has nothing to do with the block or heads ) .
The only problem you would have with the Predator heads is keeping your front wheels on the ground ..
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: B1 TS Heads Info [Re: gillman34] #558831
12/20/09 10:47 PM
12/20/09 10:47 PM
Salt Lake City
Salt Lake City
It was something about the canted valve design and the piston shape with the wedge head deal, that caused excessive detonation. I really didn't want to have to change headers, as mine cost alot. But, it's good to know some have good luck with them. It will either be Predator or B1 PSO's when I make the move.
Re: B1 TS Heads Info [Re: camastomcat] #558832
12/21/09 01:37 AM
12/21/09 01:37 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
With the TS heads we have to remember there are many different kinds to choose from.
The ones on my 636ci are the 4.840 bs option which changes the block. There are some rare ones that are 4.900bs
My heads only flowed around 500cfm.
For the geometry my engine has had the lifter holes moved over .100 and then i run a .210 offset lifter which starts straightening everything up which allows bigger pushrods.
Give Scott a call and he can tell you more than anyone. I know that Scot has some real special TS heads that flow a lot more that 530. But i think there are only a few out there.
Re: B1 TS Heads Info [Re: camastomcat] #558833
12/21/09 02:07 AM
12/21/09 02:07 AM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
Lots of canted valve engines out there--almost every serious race head has canted valves.
Re: B1 TS Heads Info [Re: camastomcat] #558834
12/21/09 08:56 AM
12/21/09 08:56 AM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
Predator heads have a VERY flat intake valve angle (10 degrees). This angle dictates the shape and height of the combustion chamber. So called "flat" chambers are very efficient and do not need a lot of ignition timing. This is even more true when using nitrous. It is very common for people not to pull enough timing when using nitrous. This would one situation that would "beat the mains out."
Its the tune up not the heads!
Mike @MM
Re: B1 TS Heads Info [Re: camastomcat] #558835
12/21/09 10:25 AM
12/21/09 10:25 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
the Predators would rquire different headers..you could use yours on the PSO if the tubes are big enough. The PSO is the best true wedge head currently produced, but..it cant match the flow of the the splayed valve heads like the Predator, TS, Big Chief, etc.
Re: B1 TS Heads Info [Re: B1Fish540] #558836
12/21/09 02:36 PM
12/21/09 02:36 PM
Salt Lake City
Salt Lake City
That's what I have to think about, whether the extra power of the PSO's will get me where I need to be, and I really need 150 more HP.
Re: B1 TS Heads Info [Re: camastomcat] #558837
12/21/09 02:46 PM
12/21/09 02:46 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
If your Originals are fully ported, I think it would be close. I think Pete Costa said he is getting a tad over 500 CFM now from his PSO. Thats about 75 CFM over your Originals and that would = 150 hp.
Re: B1 TS Heads Info [Re: B1Fish540] #558838
12/21/09 02:57 PM
12/21/09 02:57 PM
Salt Lake City
Salt Lake City
500 CFM would make up my mind. Then I'd just need money. If that's Pete at Best machine, I thought he said they would flow around 470 CFM, and I don't know if that's worth the $10,000 for heads, intake, pistons ect. That's my dilema.
Re: B1 TS Heads Info [Re: camastomcat] #558839
12/21/09 03:16 PM
12/21/09 03:16 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I just got off the phone with Pete and he said his PSOs do flow 470 CFM. But in comparison to other Original motors he has built they make about 175 more HP! You might want to give him a call.
Re: B1 TS Heads Info [Re: B1Fish540] #558840
12/21/09 03:59 PM
12/21/09 03:59 PM
Salt Lake City
Salt Lake City
One thing is for sure, even though the T/S heads make more power, but I don't need to go comp racing, and they are not without a long learning curve. I think the PSO's are the best bet for trouble free operation, with the least cost, as I don't want to replace headers. I have 2 sets: 1 are stepped 2/14 to 2 3/8 and the others are 2/38 all the way. So...thanks for all the help guys, and continue to post as it is always a learing experience on this forum.
