Re: Fitting cam bearings? [Re: John_Kunkel] #558634
12/21/09 05:04 PM
12/21/09 05:04 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Just a guess based on the poor job with other machining operations on many factory blocks,they used a old cam core with grooves cut in it to make it usable. The problem would be that every set of cam bearings installed in that block will need "work" if the bores are not correct. I prefer Mikes plan but other methods obviously are doable.
Re: Fitting cam bearings? [Re: John_Kunkel] #558635
12/21/09 05:55 PM
12/21/09 05:55 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
If it's a block problem what did the factory engine plant do to size the bearings?
This is what I would like to know too.
If 10 out of 10 blocks were out of spec that you checked, this would indicate that a Major majority of the blocks were out of spec.
What a Major Unproductive PITA that would be to have to clearence that many blocks. mike
Re: Fitting cam bearings? [Re: Sport440] #558636
12/21/09 06:19 PM
12/21/09 06:19 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
We also hone the cam tunnel like MM for proper babbit cam bearing fitment.... just did 2 R3's today.
Have never had a cam go in "tight" & bearings need scraped, when the tunnel was properly sized before bearing installation.
