Re: 323 gear
[Re: roy2345]
#556469
12/17/09 10:47 PM
12/17/09 10:47 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
look in the archives. there is a speedo gear chart
I am truckless..
Re: 323 gear
[Re: roy2345]
#556471
12/18/09 01:26 AM
12/18/09 01:26 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Changed out my rear end chunk 2day. from a 2.76 to a 3.23. I notice that the speedometer is off. How can this be corrected? it says 70mph but cars are flying by me. So I cant be going 70.
Hey, did you noticed a nice improvement with the change?
Re: 323 gear
[Re: roy2345]
#556478
12/18/09 12:24 PM
12/18/09 12:24 PM
Posts: 415 Indiana
Pentastar440
Indiana
What kind of car is this in ? The 2" exhaust is not ideal but a 440 should smoke street tires even with a high geared rear. Does your engine run 'strong' or does it bog ? You may have problems with your timing or carb setup. I don't think the gear is your problem.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 323 gear
[Re: roy2345]
#556483
12/18/09 12:46 PM
12/18/09 12:46 PM
Posts: 415 Indiana
Pentastar440
Indiana
A stock engine out of a '70 New Yorker should be able to pull a tree out of the ground in low gear. I would work with the timing curve and the carb before I made too many changes. If your timing chain is badly worn, then it could be part of your timing problem ? It looks like you have a nice car to work with. Don't go too wild with you new cam or it will kill your bottom end without gears/converter.
