Re: 505 motor made 805 hp [Re: jyrki] #55573
04/01/08 09:48 AM
04/01/08 09:48 AM
AndyF Offline OP
AndyF  Offline OP
I was using the Joe Gibbs break in oil which is a fairly heavy oil. That could be the case, maybe a synthetic oil would have more film pressure.
It seems to me that the spray bar would have to be on the carb side of the valve cover rather than on the top of the valve cover in order to really have a chance of getting the oil into the cups. But that seems a little complicated, it just seems easier to buy roller lifters that oil the pushrods and then get pushrods with holes in each end. That would solve the problem and wouldn't cost much more if anything.
Re: 505 motor made 805 hp [Re: AndyF] #55574
04/01/08 10:06 AM
04/01/08 10:06 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Once you get your oiling issue figured out, I would love to see the intakes compared.
I am needing to make a decision on intakes for my car. I now run the 440-2 and it with the 2 inch spacer/adapter it burries the carb in the scoop. But the 3x is just a 1/4 inch shorter than the -2 with 2 inch spacer. The 440-3 is the only good option I have and I dont want to give up HP to use it.
Re: 505 motor made 805 hp [Re: AndyF] #55575
04/01/08 10:07 AM
04/01/08 10:07 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
FWIW, one of my customers is running the 572-13 heads with 1.7 Jesel rockers and a .775 lift cam, using the spray bar valve covers.
3 seasons, no problems at all.
another has a 622 with 600-13 heads, .880 lift cam, triple springs, 1.75/1.7 rockers.....no problems with the spray bar oiling.
all im saying is.....there are plenty of people out there using it succesfully, so its not like it wont work.
both of those motors are running ball/ball pushrods.
Re: 505 motor made 805 hp [Re: AndyF] #55576
04/01/08 10:09 AM
04/01/08 10:09 AM
NC
440Jim Offline
440Jim  Offline
NC
Last time it was on the dyno it made about 740 hp. Major change was from a big flat tappet cam (Comp MM305) to a roller cam. The roller cam had a few degrees less duration than the flat tappet but a ton more lift. Lift went from .650 to .830 on the intake side.
I bet if you look at the duration at 0.200" tappet lift, you will see the roller has more duration giving "area under the curve" for more cylinder filling.
That is one stout combo.
Re: 505 motor made 805 hp [Re: AndyF] #55577
04/01/08 10:13 AM
04/01/08 10:13 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Cool deal, thanks for the update.
Re: 505 motor made 805 hp [Re: AndyF] #55578
04/01/08 10:21 AM
04/01/08 10:21 AM
So. Burlington, Vt.
So. Burlington, Vt.
805 hp at 6400 rpm and 670 ft-lbs at 6100 rpm were the peak numbers.
are you saying the peak TQ was at 6100, and the peak HP occurred only 300rpm higher?
or, was that as high as you ran the motor?
Re: 505 motor made 805 hp [Re: fast68plymouth] #55579
04/01/08 10:57 AM
04/01/08 10:57 AM
NC
440Jim Offline
440Jim  Offline
NC
I was thinking the same thing. I would think if all was working well, it would make even more power higher up.
Re: 505 motor made 805 hp [Re: fast68plymouth] #55580
04/01/08 11:58 AM
04/01/08 11:58 AM
AndyF Offline OP
AndyF  Offline OP
Those were the peak numbers recorded on the run but the dyno operator was backing off the load since the torque gauge needle was pegged. My guess is that the motor would've made a little more power on a SuperFlow or DTS setup that was capable of more power. On the other hand, we might have just blown the bottom end out of the block if we had loaded it hard for another 1000 rpm.
Jim - actually the roller cam has less duration at 50 and 200 than the MM305 flat tappet. I'm pretty sure it has more duration at 300 lift and above though but I didn't measure those points. I think this is just an example where the published cam info doesn't really convey the full picture.
Actual numbers on the camshaft: MM305 intake lobe is 305/279/197 for the seat duration, 050 duration and 200 duration. This roller cam was a 1722 intake lobe which is 308/275/195 so a tiny bit bigger on the seat but a tiny bit smaller on the 50 and 200 duration. These cam lobes were selected to have identical duration to the flat tappet but more lift. That was one of the things I was interested in looking at.
Of course, it isn't apples to apples since I used a 1.50 rocker arm with the MM305 and a 1.70 rocker arm with the roller. The bigger rocker arm ratio gets the valve open sooner so the valve sees more duration.
Re: 505 motor made 805 hp [Re: AndyF] #55581
04/01/08 12:04 PM
04/01/08 12:04 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
( This is a stock block with stock main caps so at 800 hp we're living on borrowed time.) AndyF, the F is for Fearless!
Re: 505 motor made 805 hp [Re: earlybee] #55582
04/01/08 12:34 PM
04/01/08 12:34 PM
mikemotorhead Offline
super street
super street
"all im saying is.....there are plenty of people out there using it succesfully, so its not like it wont work."
both of those motors are running ball/ball pushrods. "
I have 2 seasons on my Ball/ball Jesel combo with the spraybars and have not had any problems!
Mike
Re: 505 motor made 805 hp [Re: earlybee] #55583
04/01/08 12:47 PM
04/01/08 12:47 PM
San Diego
StrokedDart Offline
StrokedDart  Offline
San Diego
or Foolish Impressive numbers indeed bro Gives me some new ideas.
1968 Dart
Re: 505 motor made 805 hp [Re: fast68plymouth] #55584
04/01/08 12:56 PM
04/01/08 12:56 PM
AndyF Offline OP
AndyF  Offline OP
One other explanation is that the torque peak is a false reading. The operator might not have loaded the motor enough in the lower rpm range to get the full torque curve. Now that I've looked at the print out more I'm starting to suspect that was the case. Usually on this dyno it takes a few pulls for the operator to get used to how a new motor takes the load. Since the pushrod problem showed up we stopped making pulls before we had gotten one that felt really good.
Update on the pushrod oiling issue: I talked to Russ at Indy and he says that I was supposed to remove the oil line restrictor in the valve covers for break in. After everything is broken in then you put the restrictor back in the line. I guess that makes sense but without any instructions it was something that I figured out on my own.
