Powdercoating: Is it worth the cost over paint? #555508
12/16/09 03:05 PM
12/16/09 03:05 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I have a k-frame and some other suspension components that I need to refinish. My question is, is powdercoating worth the extra expense over some type of paint? I want a good finish that will resist oil and grease but I don't really want to spend extra money for powdercoating if there is a paint that is as durable.
Re: Powdercoating: Is it worth the cost over paint? [Re: 1970RT] #555509
12/16/09 03:13 PM
12/16/09 03:13 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I had mine done. If you add up the price of a good quality paint, all the materials that go with it, and having to pay someone to blast and paint it for you if you can't do it at home then the price of painting doesn't look so affordable.
Re: Powdercoating: Is it worth the cost over paint? [Re: 1970RT] #555510
12/16/09 03:15 PM
12/16/09 03:15 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I used a paint similar to por 15 and used a foam brush and reduced the paint some so it would lay nice and smooth. It's really strong and durable and looks almost just as good... and alot cheaper!
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Powdercoating: Is it worth the cost over paint? [Re: Silver70] #555511
12/16/09 04:49 PM
12/16/09 04:49 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
I think powdercoating is overhyped. I see it fail all the time, especially on brackets that have an edge on them, like ones made out of 1/8 inch steel. The coating fails right on the edge and starts rusting underneath. My Westin side rails on my Rubicon are doing it now, and already had to replace the KC light brackets for the same reason, only about a year old
Re: Powdercoating: Is it worth the cost over paint? [Re: donbarnes] #555512
12/16/09 04:55 PM
12/16/09 04:55 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I also think it's overhyped. I see guys powder coating valve covers, fan blades and engien accessory brackets. Yeah it looks nice and is durable, but most of that stuff doesn't take any damage or contact once it's bolted in. Like your K frame. Do a decent job of cleaning it and painting it, what's going to happen? Unless you plan to take your car 4x4ing. It looks great, but whether it's worth the money is up to you.
Re: Powdercoating: Is it worth the cost over paint? [Re: DaytonaTurbo] #555513
12/16/09 05:00 PM
12/16/09 05:00 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
I did my battery tray only, but the only reason was corrosion resistance, everything else has paint on it.
Re: Powdercoating: Is it worth the cost over paint? [Re: DaytonaTurbo] #555514
12/16/09 05:02 PM
12/16/09 05:02 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
If i remember right, dayclona mentioned he used base/ clear coat paint on a lot of suspension parts and it seemed to work pretty good. not sure how the price between that and powercoating differs though.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Powdercoating: Is it worth the cost over paint? [Re: mopars_1] #555515
12/16/09 05:05 PM
12/16/09 05:05 PM
Manitoba, Canada
Manitoba, Canada
Also one guy I know was getting something for his car powder coated, he said they charged him for the rack so he squeezed on as many odds and ends as he could. I would do the same in that situation.
Re: Powdercoating: Is it worth the cost over paint? [Re: DaytonaTurbo] #555516
12/16/09 05:19 PM
12/16/09 05:19 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
That's how I did it.
Re: Powdercoating: Is it worth the cost over paint? [Re: RokketRide] #555517
12/16/09 05:33 PM
12/16/09 05:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Between how durable properly prepped powdercoating is.. And what it costs when you get the right connection... I feel it's very worthwhile...
My cost for all this stuff was around $600.00 (I actually traded labor)
BTW if it peels around the edge that probably means they took the raw steel parts & powdercoated them without any prep... IE blast the steel to give it some mechanical adhesion..
Re: Powdercoating: Is it worth the cost over paint? [Re: 1_WILD_RT] #555518
12/16/09 05:34 PM
12/16/09 05:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
2
Re: Powdercoating: Is it worth the cost over paint? [Re: 1_WILD_RT] #555519
12/16/09 05:34 PM
12/16/09 05:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
3
Re: Powdercoating: Is it worth the cost over paint? [Re: 1_WILD_RT] #555520
12/16/09 05:35 PM
12/16/09 05:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Powdercoating: Is it worth the cost over paint? [Re: 1_WILD_RT] #555521
12/16/09 05:52 PM
12/16/09 05:52 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I like powdercoating, but have had good luck with rust bullet type paints..
I buy the small HF sprayer and get a qt of paint and blast and clean the parts, sometimes ospho them... When the cheapy sprayer wears out I just throw it away and get another.....
PS. they never get cleaned very well either.. The Lacquer thinner costs more than the gun..
Re: Powdercoating: Is it worth the cost over paint? [Re: minivan] #555522
12/16/09 06:34 PM
12/16/09 06:34 PM
Long Island NY
yellow sixpack Offline
Long Island NY
Worth the money!
If you can't be smart.....don't be stupid!
Re: Powdercoating: Is it worth the cost over paint? [Re: yellow sixpack] #555523
12/16/09 06:55 PM
12/16/09 06:55 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
For years I've been having the kids' racing kart frames powder coated for 2 reasons:
1) it was easier than me blasting and painting them
2) one of the club members owned the company and did them for less than I could buy paint for
HOWEVER, the powder doesn't stand up to laquer thinner, brake cleaner, varsol or gas. While these chemicals won't strip it away, they will definately ruin finish.
There are paints out there that will easily stand up to these chemicals. If you paint the stuff yourself you can redo or touch up anything that gets buggered up in the future. This can't be said for powdercoat. If it dulls, chips, or whatever, you're screwed.
Yeah, all that stuff looks pretty sitting on a blanket, and it'll look real nice on a trailer queen, but let's see it on a driver after putting some wear and tear on it.
Re: Powdercoating: Is it worth the cost over paint? [Re: Stanton] #555524
12/16/09 07:10 PM
12/16/09 07:10 PM
indiana
generallee6901 Offline
indiana
I had all the suspension pieces and engine pieces painted on my charger 6 years ago and still looks good.Is a lot easier to clean.But some chemicals will scratch it.Depending on the color it could be real noticable.While i do not drive my car very often it does get driven.I do not own a trailer and do take it on long drives and clean up is a lot easier.Defeinitly worth the cost if the person who does it does it right.I had my k-frame dipped before it was coated to get everything inside.
Re: Powdercoating: Is it worth the cost over paint? [Re: generallee6901] #555525
12/16/09 07:17 PM
12/16/09 07:17 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
one thing to not overlook to is e-coating. that started out as a base for powdercoating and in my eyes is the BEST way to do it. you know it was thoroughly cleaned before paint (goes through a wash to remove any "light" oils) it gets submerged in a tank so it has paint EVERYWERE and the millage is perfect all the way across.
Re: Powdercoating: Is it worth the cost over paint? [Re: Stanton] #555526
12/16/09 08:15 PM
12/16/09 08:15 PM
Charlotte NC
DCI Offline
DCI  Offline
Charlotte NC
Not true. I can restore any powder just like you can any paint. What do you do to restore faded paint? Do the same thing to powder. I can touch up customer chips no matter it if is smooth or textured powder. If you get a solvent on it just give a wax with anything you would use on you normal paint job...good as new. You can even wet sand and buff it like you would a high $$$ paint job.
I have parts on cars that have been driven regularly for years and it still looks brand new. I have lawn chairs that have sat outside year around for years and still look nice and glossy to this day. I can prep and coat a Q panel with powder and beat it to death with a sledgehammer and the panel dents but the powder never lets go.
If PREPPED and applied correctly powder is far tougher than any normal realistically priced paint out there.
Lot of bad coaters out there and when done wrong powder is weaker than paint.
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block." Those words must have left a bad taste in his mouth!
Re: Powdercoating: Is it worth the cost over paint? [Re: DCI] #555527
12/16/09 08:22 PM
12/16/09 08:22 PM
Manitoba, Canada
Manitoba, Canada
Yeah you can, but can the average guy touch up a powder coat in his home garage?
