Re: FYI Steering shaft dissection101
[Re: JohnRR]
#55529
03/31/08 01:47 PM
03/31/08 01:47 PM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
" I hear of others bolting, riviting, and even welding the shafts togeather." ![](/ubbthreads/images/graemlins/tsk.gif) Thanks for the input guys. I'll stick to my method for now. Jules
my father had to be cut out of a 65 mustang that he was pinned in when he tangled with a 54 olds , it wasn't pretty .
Back in the old days there were no collasable columns. The real kiss of death were the cars with the gear box out in front of the axle. Ouch,,,, That had to hurt.....
[Re: KillerBee]
#55531
03/31/08 02:11 PM
03/31/08 02:11 PM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
Thanks for the info. ![](/ubbthreads/images/graemlins/thumbs.gif)
I'm currently going from manual steering to power in my 1971 Challenger. From what you see will it be possible to collapse my longer manual steering shaft by hammering the shaft in and make it work on a power steering box?
So how about the oposite. Can a power shaft be lengthend to fit a manual box?
[Re: CUDAJAS]
#55532
03/31/08 02:18 PM
03/31/08 02:18 PM
Posts: 2,984 Montreal,Quebec,Canada
JulesdaWiperman
super gas
super gas
I would say not a good idea. You would not be left with enough solid shaft entering the tube shaft. Robert, I would never do that to you. ![](/ubbthreads/images/graemlins/grin.gif) Jules
[Re: RoadRunner]
#55534
03/31/08 04:31 PM
03/31/08 04:31 PM
Posts: 821 NW Ohio
6pkaar
NW Ohio
I am not sure I would use epoxy either. I think it would bond the two halves together.
Would it work to put an extremely thin layer of grease to the areas the epoxy is exposed to to keep from bonding the two pieces together?
[Re: CUDAJAS]
#55535
03/31/08 05:00 PM
03/31/08 05:00 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
I think they sell an adaptor for that.
[Re: CUDAJAS]
#55536
03/31/08 05:02 PM
03/31/08 05:02 PM
KillerBee
N.E. Ohio
![](http://www.firmfeel.com/img/coladp.jpg)
[Re: KillerBee]
#55538
03/31/08 05:54 PM
03/31/08 05:54 PM
CUDAJAS
Yeah, I know but it is ugly!!!!(and pricy)
Thanks Jules. I have a power column but will rethink using it. Maybe look for a trade.
Jas
[Re: KillerBee]
#55545
04/01/08 07:39 AM
04/01/08 07:39 AM
CUDAJAS
Big THANK YOU to Jules for taking the time to photograph the shafts!
Yes Thank you so much.
I am definatly going to rethink my column repair now!!!
That is quite a difference.
[Re: KillerBee]
#55546
04/01/08 10:51 AM
04/01/08 10:51 AM
Posts: 327 Northern BC
Canucklehead
Northern BC
Yes, thanks a ton! When people ask about it I've always told people I didn't think it was a good idea so it's nice to see the proof.
