Page 3 of 3 1 2 3
Re: FYI Steering shaft dissection101 [Re: JulesdaWiperman] #55549
04/01/08 03:23 PM
04/01/08 03:23 PM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
I'm just in the process of doing this on a shaft also and am trying to decide what to fill the void with. My first thought was epoxy too, but if its an epoxy that can bond metal, won't the shaft be effectivly bonded - maybe not as much as a weld, but close? As said above, to use a plastic it has to be fairly thin to flow in the cavities.
Re: FYI Steering shaft dissection101 [Re: 65Frank] #55550
06/09/08 12:52 PM
06/09/08 12:52 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Why is so much effort being spent in "repairing" the shafts. Where are they going to go? You, Jules, said you needed a sledge to remove the shafts from each other. You are restoring them, so I see why you are doing it, but for the rest of us, who will ever see it? The upper shaft is held in at top, and the lower shaft is held in at the steering box. The only force on them is in rotation.
Re: FYI Steering shaft dissection101 [Re: 375inStroke] #55551
06/09/08 01:14 PM
06/09/08 01:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
There is a right and wrong way to restore or repair a shaft. Doing it right will have several benefits. 1- Its safe. 2- It wont rattle. 3- Its done correct and not hacked up.
Re: FYI Steering shaft dissection101 [Re: NITROUSN] #55552
06/10/08 12:24 AM
06/10/08 12:24 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
It also looks like Julius is replating the shafts with a brite dip coating which will destroy the plastic..
I am currently rebuilding my column and I am going to use the epoxy method.
Also I found the perfect tool to seperate the two shafts...(Torsion bar remover on left of pic)
Page 3 of 3 1 2 3
