Re: AFTERMARKET WEDGE BLOCKS,WHICH ON TO BUY??
[Re: b1headman]
#555185
12/18/09 11:11 AM
12/18/09 11:11 AM
Posts: 19,395 Las Vegas
Al_Alguire
Las Vegas
Chevy Ultrabells are cheaper than Mopar Ultrabells. Simple as that, cost less money. You could also just run a complete Chevy glide/TH400 etc and use a CSR one piece shield, even less money than a bell and blanket/case/shield. I have a KB Block with a Mopar trans pattern but the midplate acts as an adapter. I use a Chevy trans on mine. One other benefit, if you travel to race and have a trans issue it is gonna be a lot easier to find a Chevy type trans than a TF.
[Re: Al_Alguire]
#555186
12/18/09 12:44 PM
12/18/09 12:44 PM
Posts: 627 IN
BIG BEAR
IN
But wouldn't you STILL need a mid plate to bolt the starter to??? I understand that you want to keep cost down and using chevy parts will be cheaper. I'm not saying that the dual bellhousing idea is a bad one, I'm just trying to figure out how it works.
[Re: BIG BEAR]
#555188
12/20/09 02:41 PM
12/20/09 02:41 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
was surfing around and found this PG to BBmopar adaptor kit that allows use of stock location mini starter. PATC product.
