Re: AFTERMARKET WEDGE BLOCKS,WHICH ON TO BUY??
[Re: CompWedgeEngines]
#555166
12/16/09 08:39 PM
12/16/09 08:39 PM
Posts: 627 IN
BIG BEAR
IN
Its funny, it used to be we couldnt get anything, then we had everything, then there were none, now we have a few, and Hemi blocks are in abundance. Go figure.
You are right, it is funny how it is all playing out. When we started casting, we had no idea that someone would want our blocks in a smaller bore. Now we are seeing more people lean that way.
[Re: The Avg. Valiant]
#555167
12/16/09 08:51 PM
12/16/09 08:51 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Koleno, World, KB. Metal Storm is using the Koleno with his blower app, and he is street strip. May want to talk to him.
the block just got finish bore.time to start checking my parts clearances.i am ordering all my gaskets,rings this week. ![](/ubbthreads/images/graemlins/boogie.gif)
[Re: flathood]
#555169
12/16/09 09:17 PM
12/16/09 09:17 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
4.490 Siamese 301#. Just weighed some.
Also weighed a bare Indy Maxx....137#
Stock 440 229#
RIP Monte Smith
#555170
12/16/09 09:49 PM
12/16/09 09:49 PM
i sure miss the old MP Megablocks w/ 4 bolt mains. the ones that sonic check batter tham 4.310
[Re: blownzoom440]
#555171
12/16/09 10:28 PM
12/16/09 10:28 PM
Posts: 627 IN
BIG BEAR
IN
Sweet METAL STORM, can't wait to see what she'll do! ![](/ubbthreads/images/graemlins/thumbs.gif)
#555172
12/16/09 10:33 PM
12/16/09 10:33 PM
Posts: 627 IN
BIG BEAR
IN
Stock 440 229#
An aftermarket block that was iron weighing less than stock would scare me. There is a reason why Koleno blocks as well as World blocks are so heavy ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: sasquatch]
#555175
12/17/09 08:53 AM
12/17/09 08:53 AM
Posts: 627 IN
BIG BEAR
IN
AH that 137 is the aluminum version. Indy does not make an iron block. They did long ago but they weigh a ton. TOdd
Yes, your right Todd. I think most aftermarket aluminum blocks will weigh about the same. I was just pointing out that aftermarket iron blocks will weigh more than stock iron blocks because they are designed better. Thats why an iron block now is around 300lbs vs 230lbs back then.
[Re: flathood]
#555176
12/17/09 01:11 PM
12/17/09 01:11 PM
Posts: 627 IN
BIG BEAR
IN
Looking around,the koleno block is slightly more $$ than the world block but the koleno has all 5 main caps bolted,world only 4.Koleno has the priority oiling,arp hardware and bushed lifter bores.What does the world block weigh?Koleno is 300 even.
Just like everything else, the best thing to do is weigh out all the costs vs options ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: moparniac]
#555178
12/17/09 03:06 PM
12/17/09 03:06 PM
Posts: 627 IN
BIG BEAR
IN
not to start anything here as im sure the kaleno is a nice peice but I got my world aluminum block with bushed lifter bores extra ribbing across the valley and the back of the block is drilled for a chevy tranny for under $4k! However I really like the feature of plumbing into the front of the block for the oiling system cause this is going into an A body.... moparts is a great to help you make the right decision for us "rookies" ![](/ubbthreads/images/graemlins/biggrin.gif)
![](http://img196.imageshack.us/img196/5425/myblocksmall.jpg) They make a 3/8th to 1/2" adapter if you wanna run a pickup or just have it plugged up like mine for external oiling... no more drilling!
![](http://img140.imageshack.us/img140/6016/myblock1small.jpg)
![](http://img134.imageshack.us/img134/8084/myblock9small.jpg)
![](http://img683.imageshack.us/img683/5351/milodon.jpg)
![](http://img689.imageshack.us/img689/9219/newmill.jpg)
I bought everything from the board sponsors on here!
If you don't mind me asking, how do you mount a starter if you use a chevy trans?
[Re: Chris'sBarracuda]
#555181
12/18/09 12:09 AM
12/18/09 12:09 AM
Posts: 627 IN
BIG BEAR
IN
Mid plate adapter kit.. ![](/ubbthreads/images/graemlins/thumbs.gif)
Chris..
Then what would be the advantage of a dual bellhousing block ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: BIG BEAR]
#555182
12/18/09 12:14 AM
12/18/09 12:14 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
OK.. I misunderstood your question.. ![](/ubbthreads/images/graemlins/confused.gif) You would bolt it in the same place and get a 130 tooth flexplate/flywheel.. www.reactorproducts.com ask for Olan Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
#555183
12/18/09 08:39 AM
12/18/09 08:39 AM
Posts: 627 IN
BIG BEAR
IN
OK..
You would bolt it in the same place and get a 130 tooth flexplate/flywheel.. ![](/ubbthreads/images/graemlins/thumbs.gif)
Chris..
What I mean is, how does a dual bellhousing block help you? How would you mount a starter??? Thats all I was getting at ![](/ubbthreads/images/graemlins/penguin-015.gif)
