Re: Plug Wires vs Headers
[Re: sunroofgtx]
#554899
12/20/09 10:24 AM
12/20/09 10:24 AM
Posts: 15,487 Florida
scratchnfotraction
I dont see the wires running exactly like the ones with the mannys how is all the wires on the drive side going to go behind the tubes? they angle back to the side of block to clear the frame same on pass side..the #8 will drop behind the head,but how are the 2,4,6 goona fit behind the tubes of the header? main reason I went with 2 center dump mannys,2 in back of head and 2 in front of head on both sides with all 90* boots I will have to study the pics more..but I dont see them working with headers the same as the HP mannys sparky posted
[Re: scratchnfotraction]
#554900
12/20/09 05:55 PM
12/20/09 05:55 PM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
I have to agree with Mike, the headers cut back towards the block, so there's not as much room as there appears. I could be wrong. Who knows. Attached is a pic of how I would like to run the wires. Rick, let me know if we can do something like that. About the spark plugs, does Champion make a short header plug to fit the 5/8 452 heads? I prefer using Champions, but would also consider using Autolites. Are the short header plugs available? Anyone have any part numbers? Would be appreciated! Landon, I'm sure you've heard this before, but loose that air cleaner!!!!! Gas and fumes from the carb will splash up and eat up the foam, which then gets sucked up in the engine. Been there, done that! I know it's cheap and kinda cool looking, but it's not worth the money you spent on your motor!
[Re: dodgeram440]
#554901
12/20/09 07:49 PM
12/20/09 07:49 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
Had to comment on not seeing anything covering the top of the carb while on the stand. We destroyed an expensive Pontiac Superstock motor 20 years ago because a magnetic screwdriver bit fell down in there, and upon startup, it ran for about 10 seconds, and stopped very quick. The bit had jammed itself between the piston and the cylinder wall. Don't want anyone else to ever go through that.
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: dodgeram440]
#554902
12/20/09 07:58 PM
12/20/09 07:58 PM
Posts: 6,516 Santa Cruz, California
Lefty
My question concerns the use of headers and what type of plug wires do I need: straight boot or 90 degree?
I've had the best fit with headers using the 135 degree boots.
[Re: zzyzxpat]
#554903
12/20/09 09:51 PM
12/20/09 09:51 PM
dodgeram440
Piqua, Ohio
Won't be a problem on this one...nothing is bolted on. In fact, at this moment, the carb is sitting on a shelf. The intake is just sitting on there, holding the belly pan in place, with masking tape over the port holes. I also peeled off the old masking tape over the exhaust ports when I set the headers on for the pics, then recovered with new tape when I was done. There is also a shop rag that is stuffed in the distributor hole. The only thing that really isn't "sealed up" is the water jackets around the water pump housing, which is just kinda held in place with a couple loose bolts. I know this probably isn't the best way to store an engine, but it's what I've got. I have pulled the plugs and shot some wd-40 inside and turned it over by hand. Probably wouldn't hurt to do that again.
But thanks for looking out for me.
[Re: 70Cuda383]
#554904
12/21/09 01:51 AM
12/21/09 01:51 AM
Posts: 12,132 Cleveland
sunroofgtx
Cleveland
I think if he got the short spark plugs it would work fine. 135 boots look like they are too long for 2 and 8 for sure. Even bending them to a 90 , they stick out 2 inches.Try finding the shorty spark plugs . Lets do it right the first time.Get the plugs and then take pics from the front, plug heigth.. We'll see.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: dodgeram440]
#554906
12/21/09 02:55 PM
12/21/09 02:55 PM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
Accel makes them for sure.I ran a set of headers like those for yesr.Ran the regular plugs with the Taylors and even a set of Morosos and had no problems.I did ding the tubes on a few a little to get more clearance.Rocky
Chrysler Firepower
[Re: dodgeram440]
#554910
01/03/10 10:01 PM
01/03/10 10:01 PM
sunroofgtx
Cleveland
Bill, so do you think all 90's will work, however you route them? Like the routing of your yellow wires in the pic, are those all 90 degree boots? Looks good.
[Re: dodgeram440]
#554912
01/20/10 10:41 AM
01/20/10 10:41 AM
Posts: 467 Keminmaa
ArcticCuda
Keminmaa
Hi, here comes my pictures. I got extra good service from Custom Wire Sets / Rick!
1970 Plymouth GTX 440-6 1970 Plymouth PPR Cuda 489-4 1971 Plymouth Duster Bad Romance 408-W2-8bbl
[Re: ArcticCuda]
#554913
01/20/10 10:43 AM
01/20/10 10:43 AM
Posts: 467 Keminmaa
ArcticCuda
Keminmaa
Fits nice
[Re: ArcticCuda]
#554914
01/20/10 10:44 AM
01/20/10 10:44 AM
Posts: 467 Keminmaa
ArcticCuda
Keminmaa
Relocated coil. Extra long wire from Custom Wire Sets!
[Re: ArcticCuda]
#554915
01/20/10 10:49 AM
01/20/10 10:49 AM
Posts: 467 Keminmaa
ArcticCuda
Keminmaa
This is my 383 based stroker with 4.25" crank, 440 Source aluminum heads and small hydraulic cam. It gave 462 hp / 720 nm on dyno.
