How to mount Space Saver tire?
#553647
12/14/09 11:55 AM
12/14/09 11:55 AM
Posts: 5,268 NY
70440+6bbl
NY
I repainted a space saver rim and need to have the original F78-14 BFG tire mounted back on it. I found some factory warning literature where it is stated NOT to use use compressed air and to only use the inflator cannister... Has anyone done this before without damaging the tire?
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: How to mount Space Saver tire?
[Re: 70440+6bbl]
#553648
12/14/09 11:57 AM
12/14/09 11:57 AM
Posts: 5,268 NY
70440+6bbl
NY
The Space-Saver should only be inflated with the special canister provided. Never use an air hose. The canister is good for one use only; a new canister must be obtained for future use. Follow the approved mounting and use instructions. As early as possible, remove the Space-Saver and replace it with a normal tire. The Space-Saver is a load range B tire and should never be inflated past 32 psi. Because of its construction, the Space-Saver tire beads may appear to be improperly seated on the wheel. This is normal. Do not attempt to seat the beads by adding more air. To deflate the tire, remove the valve stem and fold the tire around the rim. No attempt should be made to remove the Space-Saver tire from the rim or to repair the tire.
Figure 4 Space-saver spares required special handling to preserve their usefulness
[Re: cuda-sweden]
#553650
12/15/09 12:39 AM
12/15/09 12:39 AM
Posts: 5,268 NY
70440+6bbl
NY
Thanks Cuda-Sweden, anyone else have any experience?
[Re: RTshaker]
#553656
12/15/09 12:42 PM
12/15/09 12:42 PM
Posts: 434 sweden
cuda-sweden
sweden
Is the rim of a space saver different than a regular rim?? I have a gm rim and tire that I would like to change over to a mopar bolt pattern ?? Thanks
thats what i did,pontiac aluminum space saver wheel,cut the rim in half with a vinkelslip, removed the tire and mounted it on a regular junk yard 14" rim.simsalabim a look alike space saver wheel,but with good year tire.but i can live with that until i ran into a bf-goodrich.overandout ![](/ubbthreads/images/graemlins/XmasPeng.gif)
[Re: Snoopy]
#553659
12/15/09 10:04 PM
12/15/09 10:04 PM
Posts: 5,268 NY
70440+6bbl
NY
Hi Jules,
I had a local tire shop put the tires back on (I am doing two '70 space savers), he got them ON the rim with no problem, but they are not centered and the beads do not sit right... Is that where the issue lies with these tires? I will bring them back to him and tell him to use lots more lube if you think that is the problem.
[Re: 1_WILD_RT]
#553666
10/30/11 01:45 PM
10/30/11 01:45 PM
Posts: 297 Oklahoma
TinCuda
Oklahoma
No, I have never mounted a tire without a split rim. I guess someone like Hibdon Tires would not be up to it? Sounds like they just need to get the tire on the rim, then drop it a couple of times. Like I said, I really have no idea.
(O O {]{]{]||[}[}[} O O)
1971 Plymouth 'Cuda 440-6
{||O||}
2000 Yamaha V-Max
(O O [========= SRT] O O)
2011 Dodge Challenger SRT 392
Making as big as a carbon footprint as I can!!!
