Re: IS THERE A DIFFERENCE IN BOOST??
#553405
12/23/09 11:17 AM
12/23/09 11:17 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
when you guys figure all that out let me know your theory regarding "which came first the chicken or the egg"
roflmao!!!!
Hemifred thanks for that comment!! That made my day!!
Post deleted by Defbob
[Re: DakFink]
#553406
12/23/09 12:06 PM
12/23/09 12:06 PM
[Re: DakFink]
#553409
12/23/09 01:31 PM
12/23/09 01:31 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Based strictly off boost generated with a turbo, more power based off more boost is purely efficiency.....sure a motor may mnake 500hp na, then only say 800 at 15psi....to me most of this loss of power comes from the turbine choke that comes from the turbine wheel that is to small....now go and put a turbo on there that can generate closer or less than 1 to 1 boost/backpreessure ratio then power will increse greatly, but the turbo will be laggier, what most people don't want.
With a large enough turbo a 500hp na motor can make 1000 hp at 15psi no problem.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#553410
12/24/09 04:41 AM
12/24/09 04:41 AM
DakFink
OK finally went and pulled the book of the shelf. "Dyno Testing and Tuning" After what I read in there about the SAE and there 3 different HP-correction formulas. "Which have a fudge factor of 5-11%". It all comes down to when, where and who was doing the dyno-runs and whether they used one of the SAE standards of the time or made up their own. The SAE HP correction Factors have changed no less than 5-6 times in the last 20-30yrs. You can also put you own correction factors into any Dyno Software. They even warn that if a Dyno sheet is a few years old it may be off from todays SAE Standards. To give you an example we in aviation use a Sea level Standard reading of 29.92hg @ Sea Level on a Standard Day of 70*F and 70* Humidity. SAE on the other hand has 3 variations of that. 1= 29.23hg @77*F and Dry Air 2= 29.92hg @60*f and Dry Air 3= Is metric not even gonna go there!! They did mention that "Even though no one they know of does it" that when Dynoing with boost you should be figuring in Absolute Pressure and not just Gauge Pressure. They said by not doing this your Boost Dyno Numbers will be on the low side. How Low???? Theory!! Too many numbers and uncontrollable and unknown variable to worry with!!! LAW!!! ET's never lie!!
[Re: DakFink]
#553411
12/24/09 09:36 AM
12/24/09 09:36 AM
Posts: 365 Motor City
Shaker223
Motor City
Nah, It's the MPH that does not lie.
[Re: hemi-itis]
#553412
12/24/09 02:23 PM
12/24/09 02:23 PM
Posts: 3,160 L.I. N.Y. Hemi Street
HemiGreg
Is 15 lbs of boost the same if it is produced by supercharger,procharger or turbo?
as to Als question the answer is yes. as to other read into parts of the question is no.
if you want to know about power production with each then you need to justify your parameters cause at least 12 different general variables come into play at every equation forget about 2,3,4 iterations.
starting with your local-sea level,%RH,Desisity etc. just go more inches bigger NA squeeze and best BTU fuel. AcetonePeroxide,phospergimate etc. mjust kidding for real calcs pm me and drop off the blown Hemi for testing ill push your 727 buttons.
[Re: HemiGreg]
#553413
12/24/09 10:21 PM
12/24/09 10:21 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I was wondering when the 'MAD SCIENTIST' would chime in So what calculation program is closest to reality?I would like to throw my combo at it to see,,,,,,,,,
[Re: hemi-itis]
#553414
12/24/09 11:28 PM
12/24/09 11:28 PM
Posts: 22,724 Bitopia
jcc
Bitopia
Hey guys, Einstein said something like this: "Somethings important can't be counted, and somethings counted aren't important", for what its worth.
[Re: bigtimeauto]
#553419
12/25/09 02:31 PM
12/25/09 02:31 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
yes the drop in pressure will help the heat made trying to force the air thru the port.i have bigger carbs also for room to grow.boost is fun.
[Re: hemi-itis]
#553421
12/26/09 12:06 AM
12/26/09 12:06 AM
blownzoom440
ELYRIA,OH
What about the bigger blower,spin it slower theory??
i am sure it putsout less heat.will it make or brake a pumpgas deal i dont think so.
