Re: Cylinder Heads and Horsepower
[Re: S/ST 3040]
#550915
12/13/09 01:03 PM
12/13/09 01:03 PM
Posts: 12,443 Kalispell Mt.
HotRodDave
Kalispell Mt.
If what you seem to be finding is true (I beleive it is) then it would throw out the theory that strokeing an otherwise identicle engine only increases TQ. We have all heard that over and over "longer stroke only increases TQ not HP" but I cry foul, a bigger motor at the same RPM is going to suck in more air because of the greater depression in the cylinder and more air means more fuel more fuel means bigger bang. The 73 340 and 74 360 are good evidance of this, same cam, heads, intake, almost identicle bore and compression ratio... the 360 makes more TQ AND HP.
[Re: HotRodDave]
#550916
12/13/09 03:19 PM
12/13/09 03:19 PM
Posts: 1,019 Finland
mafo
Finland
361" .730 lift 345cfm@ .700 9.39/143mph/2900#
351" .915 lift 400cfm@ .900 9.22/150mph/2850#
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: S/ST 3040]
#550918
12/13/09 04:28 PM
12/13/09 04:28 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Scott, if I had to guess, I'd say I've read that as many times as you have. I'm not comparing a S/S head or engine to anything here. I'm just asking for examples for my own interpretation of some general data.
If I wanted to start a pissing match about this, I could post on that thread on SpeedTalk and start calling people liars. That's not my intention nor am I saying I know anymore than anyone here. This may not prove very useful, in the end but, I'll decide whether it's relevant.
I know you're not talking about SS engines. But just because it's not a NHRA SS motor, doesn't mean that we shouldn't try to get the port size/shape right.
Sorry, I didn't intend to start a pissing match at all. That was definately not my point.
If anything I was just pointing out what all of the posted information seems to point at...CFM doesn't corrolate very well to HP.
[Re: HotRodDave]
#550919
12/13/09 04:34 PM
12/13/09 04:34 PM
BradH
I look at it a little differently... For any given CFM, a larger engine is going to be able to utilize the flow more easily than a smaller engine. Another way to explain this is the smaller engine can make the same HP, but it's going to need to be much more optimized to take full advantage of the heads.
Just my thought on the subject.
[Re: S/ST 3040]
#550921
12/13/09 07:27 PM
12/13/09 07:27 PM
Posts: 1,178 Indy
FlyFish
Indy
LIFT--IN/EX .100"--63.0/NA .200"--137.9/98.2 .300"--191.6/141.9 .400"--243.8/171.9 .450"--262.2/181.5 .500"--281.3/188.4 .550"--289.8/193.8 .600"--292.9/196.6 .650"--292.9/199.9 .700"--292.9/202.1 Cam: small solid roller 248/254 degrees w/ ~.580 lift 3250#'s, 10.8:1 compression, 11.1 @ 120 mph.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: dizuster]
#550922
12/13/09 08:17 PM
12/13/09 08:17 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
I know CFM isn't everything but, like I've told other people, who tell me that......When is the last time you saw a port that had the correct size and correct shape, that doesn't flow good air? We all strive to get all we can, for what we have. This is just some information to ponder. I'm open to ideas, too.
[Re: S/ST 3040]
#550924
12/13/09 08:46 PM
12/13/09 08:46 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
532 HP
1.53 HP per CFM
Quote: All @ 28"
.100" - 65 .200" - 145 .300" - 214 .400" - 258 .500" - 290 .600" - 299 .700" - 301
245*/.630" hyd. roller
3400 lbs.
125.62 mph
520 HP
1.76 HP per CFM
HP on one of these is off?
[Re: S/ST 3040]
#550931
12/14/09 09:33 AM
12/14/09 09:33 AM
Posts: 698 Alberta Canada
Edge
Alberta Canada
305 CFM @700 Indy SR MW 2900 lbs 135 MPH 9.85 @ 4500 feet .735 total lift engine dynoed around 665 hp
76 Duster
work in progress
[Re: Edge]
#550932
12/14/09 09:36 AM
12/14/09 09:36 AM
S/ST 3040
548 HP
1.796 HP per CFM
I'm not sure how bad the 4500 ft. really hurt it.
[Re: S/ST 3040]
#550933
12/14/09 11:50 AM
12/14/09 11:50 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Here are a few more to look at ; same motor with different induction packages. The build ; 446ci (10.5:1) stock rods/2355 SpeedPro slugs Comp Solid 264@.050/.580 lift/109 lsa Stage 1 E-heads by Dwayne 292@.550/297@.600**These #'s are from Dwayne's Dyno** (1) 535hp with Street Dominator/850 carb/1in open spacer. Best performance with this combo : 11.68@116.25 in good air. Raceweight 4100...not enough stall or gear for best ET...going out the back at 5500. (2) 560hp with Victor and Dwayne's race carb...everything else the same. This intake/carb package was never run in the car....just a test to see "what if". Ron
