Re: Cylinder Heads and Horsepower
[Re: 440Jim]
#550897
12/13/09 09:30 AM
12/13/09 09:30 AM
Posts: 2,939 A shed in England
Tig
A shed in England
Here's Mine Indy 572-13's 380 @ .700 9.57 @ 142.5 3850lb.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: S/ST 3040]
#550902
12/13/09 09:44 AM
12/13/09 09:44 AM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
Jim, I have your's at 2.11 HP per CFM
That's figured from .600" lift or max valve lift x 87%
The smaller engines don't seem to utilize the air flow available with as much efficiency.
I would think compression needs to be considered as well. If you can't get anymore in, squeeze what's in there more.
[Re: S/ST 3040]
#550903
12/13/09 10:00 AM
12/13/09 10:00 AM
Tig
A shed in England
860 HP
2.26 HP per CFM
Wow Maybe my head guys rig reads low? He always says "never pay much attention to it any way", "they're better for a before and after comparison".
They will flow a tickle over 390 @.800 (on his bench) however but my cam is .737 gross lift. With .030 lash and any geometry issues I figured .700 best where they flowed 380. Hope I haven't thrown a spanner in the works here ![](/ubbthreads/images/graemlins/blush.gif) Thanks for the info ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: S/ST 3040]
#550904
12/13/09 10:17 AM
12/13/09 10:17 AM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Vic, Cool thread. I've been thinking about how my data would apply, or if it should be used. I think the simple answer is that it would/should not.
I think that the premis is: what kind of power might be possible based upon head flow. Correct?, If so this would presume that the induction system and exhaust system are also designed to support the potential of the head. In my case the mild cam, and restrictive exhaust robs the head of its potential, and would be a nonrepresentative data point in your data set and would skew the results. Correct?
Also, would'nt you need the DA as well to adjust the actual hp numbers from the calculator to standard conditions?
If I'm mistaken, let me know, I'll throw in my data.
[Re: S/ST 3040]
#550906
12/13/09 10:56 AM
12/13/09 10:56 AM
Posts: 16,934 NC
440Jim
NC
I like the way you are doing something to account for cam lift when using the head flow number. 85% or 100% of max cam lift, I don't know, but I like the idea of not using the .800" flow number when the engine has a .600" lift cam.
As mentioned, there are lots of variables, but as long as you state what you are doing, I think it makes a useful comparison for us "typical" racers.
[Re: S/ST 3040]
#550909
12/13/09 11:25 AM
12/13/09 11:25 AM
Posts: 52,972 Romeo MI
MR_P_BODY
This could be due to the pressure differential, a big cylinder can hold the pressure differential for a greater period of time over a smaller cylinder (just thinking out loud) I know that I dont use my heads to their max ability but I didnt want to change springs all the time, but after running mine for a few years now I see that I can get away with more cam and still not have a spring issue ![](/ubbthreads/images/graemlins/wave.gif)
[Re: S/ST 3040]
#550910
12/13/09 11:34 AM
12/13/09 11:34 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
I'm really curious about this one. (NO, not because it's a BB!) I sent Dwayne one of my heads to flow and our benches are actually pretty close.
Can you give all the flow numbers and cam specs? What did it MPH and race weight?
No track times as of yet...this engine just came off the dyno a few weeks ago. It's a Heavy street car (4100 race weight) with 4.10's and 727 trans.
I don't have the flow sheet from Dwayne yet but they did peak right at 360cfm.
Cam is a .660lift roller with 266/272@.050 & 110 LSA. Installed @ 106* ICL
Ron
[Re: S/ST 3040]
#550912
12/13/09 11:38 AM
12/13/09 11:38 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I think it all just proves the point that flow doesn't mean squat. Ask the best head porters in the country and they will tell you the same thing. Port cross section and shape, are much more important then whatever flow comes as a byproduct. Just cause the head flows a lot of air doesn't mean the motor will make big HP. Just like the heads with the right port cross section and shape, may make power above their "CFM potential". It's all about having the right size/shape port, for the CID/RPM you need to run. Here is a very good thread (VERY LONG) that has a lot of good info. There is a great example on the 2nd page. It used the same SBC short block on back to back dyno tests. Same casting # heads, same CFM on the same flow bench, same exact port volume.... But head "B" made 117HP more then head "A"!!!! Like I said. Flow doesn't mean squat! http://speedtalk.com/forum/viewtopic.php?t=15709&highlight=csa
