Re: Cylinder Heads and Horsepower
[Re: JD Dart]
#550876
12/12/09 02:42 PM
12/12/09 02:42 PM
Posts: 19,404 Las Vegas
Al_Alguire
Las Vegas
Ok I will play along. Intersted to see what you get from the Moroso slide rule as we have dynoed the motor. Here you go. B1MC with oval ports done by Mike Duke Racing
444.1@ .700" 450.0@ .800" 457.2@ .900" 2910lbs 168.8mph
[Re: Al_Alguire]
#550877
12/12/09 02:48 PM
12/12/09 02:48 PM
Posts: 778 Sherwood park, Alberta.
go green
Your HP computed from your vehicle MPH is 887.05 rear wheel HP and 985.62 flywheel HP.
how did Wallace racing calculators do ?
[Re: go green]
#550880
12/12/09 02:54 PM
12/12/09 02:54 PM
Al_Alguire
Las Vegas
When I punch the number into the Wallace calculator using Weight and MPH it spits out some ridiculous number like 1146hp. I dont put alot of faith in their numbers...The engine dynoed at 1050 at Pettis' place. We all know how dyno and flow bench numbers go though. Also as Greg points out DA does have a big afect on MPH and ET numbers. FWIW when we went 168+ the DA was 1586'
[Re: gregsdart]
#550883
12/12/09 04:22 PM
12/12/09 04:22 PM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
One other variable is the coefficient of drag and frontal area of each vehicle. It does make a difference.
I agree. weight also. Compare yours, Al's and mine. you and I have the same head (-500 lbs) 15mph diff. Al has 25% more flow (+500 lbs) and run almost the same mph. Streetwise is also correct in chassis efficiency. Your ladder bar chassis could be more efficient and Al has more left in his also. I think I was lucky and had just the right match of parts and combination.
[Re: SuperStocker]
#550890
12/12/09 05:04 PM
12/12/09 05:04 PM
Posts: 12,430 Kalispell Mt.
HotRodDave
Kalispell Mt.
Another thing is the bigger motors are in similar sized cars to the littler ones, both size motors are pushing the same aproximate frontal area and if it costs both motors say 200 hp at a given speed the bigger motor will have more spare power for acceleration and apear to make more hp even if flow when up proportianly.
[Re: S/ST 3040]
#550891
12/12/09 08:37 PM
12/12/09 08:37 PM
Posts: 4,213 New York
polyspheric
New York
Better statement:
Peak CFM x .257 x Number of Cylinders, provided that the mean velocity does not fall below X during the torque range.
Otherwise, it "proves" that replacing a TF intake port with a 4" sewer pipe doubles HP.
Boffin Emeritus
