Re: Cylinder Heads and Horsepower
[Re: cheapstreetdustr]
#550836
12/11/09 07:28 PM
12/11/09 07:28 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
i have miss placed my Flow data but the heads went 380+CFM at .800 lift. 440-1 Indy head, and Indy maxx block, 440-2 cast single four intake. 4.44 x 4.5 stroke 557" 15.5:1 with a toilet injection methanol setup. 2100lbs car 175 mph. Typical 8th mile racer though...ran 143-144 mph every pass it didnt matter if it was July or October.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#550837
12/11/09 07:43 PM
12/11/09 07:43 PM
dartman366
Mt. Vernon, Ohio
Here's two senario's, #3178 weight 311 flow 268 int 274ex duration @.050 132.19 mph same but with a 277int 274ex duration @.050 this might help me decide which cam to run this next season. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: S/ST 3040]
#550838
12/11/09 07:55 PM
12/11/09 07:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Vic, here's mine 365 @.700 cam .692/.702 276/282 dur, I know I can use more cam these are the card specs I dont know what the valve see's weight 2410# speed 149 best I see it as 615 hp ![](/ubbthreads/images/graemlins/wave.gif)
#550839
12/11/09 08:17 PM
12/11/09 08:17 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
My 360: 289cfm @.500 lift .585 lift at the valve made 560HP at 7300rpm went 127.xx at 3350lbs. D.A. rougly 2200ft.
Brian Hafliger
[Re: S/ST 3040]
#550842
12/11/09 09:36 PM
12/11/09 09:36 PM
Posts: 16,934 NC
440Jim
NC
So give your typical head flow, what your car weighs and quarter mile trap speed. (I'll use Moroso's Power/Speed calculator)
0.600 334.1 252.0 0.700 350.3 264.8 0.800 368.5 280.5
279/287º @ .050" .690"/.660" lift flat tappet cam.
Race weight of 3210 lbs. and 9,21/142 MPH
Those are my numbers, do your thing.
[Re: S/ST 3040]
#550844
12/11/09 10:28 PM
12/11/09 10:28 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
hey Vic here you go 416 w/cnc Indybrocks 246/254@ 50 .590 Lift with a 108 2961lbs with me in it 4.88 with a 32x14 10.35 at 130 mph flow .100 73.7 .200 137.0 108.7 .300 199.3 150.2 .400 253.2 185.6 .450 275.2 185.6 .500 291.7 212.9 .550 302.4 219.8 .600 306.9 225.3 .650 310.5 228.8 .700 313.9 229.3 they where flowed on a 4.25 bore but are on a 4.070 x 4.00 motor ![](/ubbthreads/images/graemlins/beer.gif)
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: S/ST 3040]
#550852
12/11/09 11:36 PM
12/11/09 11:36 PM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
385 @ .800, 2470, 169
920 HP
What are your cam specs?
sorry no can do , the guy that bought it asked that I not post them. Just something I came up with to help the 440-1's on a 572. different ramps and lobes out of the CC master lobe catalog. I like the .200 durations... and it did NOT like a wide LSA.
