Re: Cylinder Heads and Horsepower
[Re: vcummins]
#550817
12/11/09 12:30 PM
12/11/09 12:30 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Vic, Feel free to post both of my combinations on here ,if you want to. You already have my flow sheets,and other information ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: vcummins]
#550818
12/11/09 12:41 PM
12/11/09 12:41 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
If your # are backing up you will have to correct that
I ported those back in 2003, before I figured out the valve job and port. I used them that way and was just giving my example....as unfavorable as it apears. They have been updated.
.100"_______62.0 .200"______127.3 .300"______188.9 .400"______241.8 .500"______269.8 .550"______268.0 .600"______269.2 .650"______269.9 .700"______273.3
[Re: S/ST 3040]
#550819
12/11/09 01:37 PM
12/11/09 01:37 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I use pipemax alot to help with HP potential and have found that if I want to achieve my HP goal, I need to either get more flow than what Pipemax suggests (if it's a street deal) or I have to use a large or semi-large cam. What I mean is, if I have 250cfm at .500 lift and I cam it small but still have .600 lift I'll come just under my HP target. This is on street stuff...on 1/4 stuff I usually exceed pipemax by a small amount. Just the difference between Larry's bench/dyno and mine I would imagine.
Brian Hafliger
[Re: Dunnuck Racing]
#550820
12/11/09 01:37 PM
12/11/09 01:37 PM
S/ST 3040
OK but, I wasn't looking to answer my own questions.
451" 3150# 277º @ .050 .682" lift flat tappet 10.47 @ 127.4 MPH
.100"_______72.5 .200"______151.6 .300"______222.9 .400"______262.9 .500"______286.8 .550"______293.4 .600"______297.9 .650"______298.4 .700"______304.2
500 HP
421" 3070# 274º @ .050" .629" flat tappet 10.20 @ 131.12 MPH
.100"_______64.1 .200"______131.6 .300"______194.4 .400"______242.5 .500"______270.8 .550"______279.3 .600"______282.2
535 HP
[Re: S/ST 3040]
#550821
12/11/09 02:58 PM
12/11/09 02:58 PM
S/ST 3040
Here's another one. (2009 EM 394")
394" 3018# 255º @ .050" .704" lift roller
9.81 @ 138 MPH
.100"_______63.9 .200"______152.9 .300"______204.4 .400"______258.2 .500"______305.2 .550"______321.1 .600"______331.7 .650"______337.6 .700"______324.4
605 HP
[Re: S/ST 3040]
#550822
12/11/09 03:45 PM
12/11/09 03:45 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
one question, on using the speed calculator: I presume this is calculating/estimating RWHP?
is the superflow formula estimating RWHP or crank HP?
[Re: S/ST 3040]
#550823
12/11/09 03:50 PM
12/11/09 03:50 PM
Dunnuck Racing
Northern Indiana
I have my reasons,..I will be getting ahold of you soon.Might have something for you to work on for me in the future. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: S/ST 3040]
#550824
12/11/09 03:53 PM
12/11/09 03:53 PM
Triple Threat
Renton Washington
Basic little 340 with OOTB eddies, I stole the numbers from Ryans site. Cam is 230/230 @.050 480/480.
.100”----72.5/N/A .200”--131.1/107.0 .300”--182.9/151.8 .400”--216.6/181.2 .450”--227.7/182.9 .500”--235.9/185.6 .550”--238.7/185.6
12.29 @ 108 3550# FWIW on a Mustang chassis Dyno the car made 280tq @4800 and 280hp @5800
[Re: patrick]
#550825
12/11/09 03:58 PM
12/11/09 03:58 PM
S/ST 3040
I'm not going to start that pissing match again.
I'd say crankshaft HP.......that's why I asked for vehicle weights and trap speeds. That way, I can compare them to the same "yard stick".
[Re: S/ST 3040]
#550827
12/11/09 04:34 PM
12/11/09 04:34 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
That would be a 69 HP drop going through the driveline, right in line with the old rule of thumb of 20% loss
Put you at 274, he saw 280 on the chassis dyno, good enough for margin of error all the way around.
I want my fair share
[Re: SomeCarGuy]
#550830
12/11/09 05:01 PM
12/11/09 05:01 PM
S/ST 3040
.....right in line with the old rule of thumb of 20% loss
Not to further but, you can't really use a percentage. Otherwise an 800 HP engine would lose 160 HP through the same drivetrain.
