Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: 6PakBee] #549372
12/12/09 08:10 AM
12/12/09 08:10 AM
Renton, Wa.
Classof70Chally Offline OP
super gas
super gas
Renton, Wa.
I was doing a search and Year One shows a "solenoid extension wire" for a 71 B body 440-6 pack but no picture. Anyone know what that might look like?
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Classof70Chally] #549373
12/12/09 08:48 AM
12/12/09 08:48 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a pic of the insulated 90* and the correct solenoid wire bracket for 70...Probably be tough to fab up the wire ends but I can get a length measurement if you need it..
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: screamindriver] #549374
12/12/09 01:16 PM
12/12/09 01:16 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Thanks for the pic, that and a measurement will help. I've got some old factory dash harnesses laying around and maybe I can pull a few terminal ends off one of them. Does your harness wire go all the way back to the alternator or does it have the 'round bullet' terminal like mine does. Thanks again.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Classof70Chally] #549375
12/12/09 01:58 PM
12/12/09 01:58 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
You can see the '71 extension in the top photo, bottom is a '70.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: BJohnson] #549376
12/12/09 03:44 PM
12/12/09 03:44 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
OK Thanks. That's not the set up I have. Mine looks like Snoopy's diagram above. I'll probably have to 'build' one that will look close.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Classof70Chally] #549377
12/12/09 04:05 PM
12/12/09 04:05 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The round bullet connection was originally for the vacuum advance retard unit... It took power from there & grounded when the throttle was closed through the insulated tab attached to the carb..
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: 1_WILD_RT] #549378
12/12/09 06:52 PM
12/12/09 06:52 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Mystery Solved. Well, it looks like the guy who did my car didn't go for the 6 pack harness with the solenoid connection so I'll make one.
