Re: What is the largest LSA you ever saw on a Mech roll
[Re: moderncylinder]
#548943
12/09/09 07:48 PM
12/09/09 07:48 PM
Posts: 3,505 DFW
mr_340
DFW
when "smart" people pick cams they look where they want the four events to occur,,, then figure the durations and seperation from there.
Jeff, I don't think that is smart as much as someone with experience. I like to think I'm relatively smart, but don't have the experience with race engines like you and Mike have. Once you've tested cams over the years, you would develop a feel for what the engine wants. For me, I'm on the beginning side of the learning curve for SS type engines. For me it's more about planning a test of cams to get where you guys are already. My DOE software can test it either way, using the opening and closing events, or durations and LSA. Reducing the number of variables to three vs. four makes the need for half as many cams to test. Advancing and retarding the cam saves that over than grinding specific cams with specific event points. Using a two-factor DOE, it only takes eight cams vs. 16 for the methods you guys use. My plan is to use lash changes to adjust durations and that just leaves LSAs to change as a screening test. I'm thinking three cams with LSAs of 108, 110 and 112 should give me a pretty good idea of what I will need if I start pretty close to the right starting point (285* on the Hemi). Keep the lobes the same on all cams, just change the LSAs. Feel free to tell me why it won't work if you can understand my methods. ![](/ubbthreads/images/graemlins/santananer.gif)
Floyd Lippencott IV
[Re: Mills]
#548944
12/09/09 08:09 PM
12/09/09 08:09 PM
Posts: 1,200 UK
602heavy
UK
A tight LSA will have a higher cranking compression
That's not always the case , take a look @ two totally different cams , one ground on a 112LSA the other ground on a 106LSA , they both have the same cranking compression...............
IO-28-IC-60--duration 268--ICL 106. EO-76-EC-20--duration 276--ICL 118. Lobe sep 112.
IO-28-IC-60-duration 268--ICL 106. EO-64-EC-32-duration 276--ICL 106. Lobe sep 106.
An interesting discussion , thanks.
Re: What is the largest LSA you ever saw on a Mech roller
[Re: turbobitt]
#548948
12/10/09 02:04 PM
12/10/09 02:04 PM
Posts: 4,211 New York
polyspheric
New York
I'm not really satisfied that event locations (IVC, etc.) are anything more than markers established after the fact, and are faux science as predictors. The engine cannot see any part of the valve train, including the valve. What does it see? Pressure differentials (is the door open or not, and which way is the traffic going - not what the door looks like, or how big it is): IVO = vacuum begins IVC = flow reversal point XVO = residual combustion pressure (balanced against pumping loss) XVC = after the wave return has peaked
The sole purpose of the position of each event is to anticipate when this pressure change will occur (or reach an acceptable level such as EVO), and if the cam gets it wrong you have no power. Opening the door to no traffic (.800" lift and no vacuum) does nothing. Leaving the door open after traffic starts moving the other way is worse.
A prediction of where X" Hg. will occur in degrees based on a cam card is not going to work, except as a coincidence.
Boffin Emeritus
[Re: polyspheric]
#548949
12/11/09 03:27 AM
12/11/09 03:27 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
I see a lot of NO NO NO, so tell us some Yes Yes Yes because I am way confused. Especially on your comment that an engine doesn't see the Valves???
From my limited experience you run too small of a valve (small door) or too big (huge Garage door) and your engine will tell you so.
Now when it comes to boost, different story. Bigger is better.
Not trying to say your wrong by no means, just trying to understand your reasoning/theory/way of thinking?
[Re: DakFink]
#548951
12/11/09 07:18 PM
12/11/09 07:18 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Optimally THEORY would say you want to open the intake as soon as possible @ TDC on the Int. Stroke an hold it open as long as possible until BDC and allow BOOST to fill the cylinders. NO OVERLAP at all and also open the exhaust as soon as possible @ BDC and hold it open until the piston has reached TDC on the ex stroke.
I wouldn't even try to guess what the numbers for that kind of cam would be.
I wont Guess, I'll give you the numbers on that cam. As you will see that cam would Suck ![](/ubbthreads/images/graemlins/smile.gif)
As you described it that cam would have a
90* LSA and 180* duration seat to seat.
For .050 duration numbers you need to subtract the number of degrees it takes a cam to get to its .050 numbers. With some Typical ramps thats about 60* to 65* When Added up, Both Exhaust and Intake
Lets use 60* to for a duration advantage. The numbers for same cam at .050 are
90* LSA 120* dur.@ .050
If we move the .050 numbers to TDC and BDC then the cams specs at .050 would be
90* LSA 180* @ .050 240* seat to seat.
Im just giving you the numbers, I know you just stated in THEORY mike
[Re: 602heavy]
#548953
12/11/09 08:56 PM
12/11/09 08:56 PM
Sport440
Canton, Ohio
![](/ubbthreads/images/graemlins/biggrin.gif)
I like it , would it run?
Oh Yea, it would run! But She wouldnt be much of a Runner though
That cam would be a down grade from any Factory Low performance production motor. mike ![](/ubbthreads/images/graemlins/wave.gif)
[Re: DakFink]
#548955
12/13/09 12:55 AM
12/13/09 12:55 AM
Posts: 761 Southington Ct.
turbobitt
Southington Ct.
Here is some more info to throw at you guys. My turbo cam was spec'd by Kenny Duttweiler with a 242/242 dur @ .050 W/113 LSA. Int opens @ 8 BTDC Int closes @ 54 ABDC Exh opens @ 54 BBDC Exh closes @ 8 ATDC With the above info, it looks like there is 16 degrees overlap. It also appears that the most that I should consider advancing this cam is 4 crank degrees with a resultant intake centerline of 109 degrees. This would put the exhaust closing event @ TDC. Assuming that there is a 1:1 relationship between boost and exhaust backpressure, and also assuming that there will be no exhaust scavenging, what are your opinions on this cam ? Advance, Retard, start with a new grind ? Add more overlap ? This cam was installed straight up @ 113 intake centerline. My ultimate goal is to enhance turbo spoolup since I'm running a large turbo. My previous performance has been 9.86 @ 137 MPH in a 3700# car with a small 76 mm turbo. Engine pulled to 7500-8000 RPM so I have room to sacrifice some top end. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#548956
12/13/09 02:08 AM
12/13/09 02:08 AM
Sport440
Canton, Ohio
Your cam does have 16* of overlap and is mild for the combo. With turbos IMO mild is all you need. Advancing the cam 4* would put it at a 109* ICL, but the exhaust closing point would be 4* ATDC not at TDC as you stated. Crank * not Cam * ![](/ubbthreads/images/graemlins/thumbs.gif) Your interests are Spooling up the Turbo faster, So IMO Id get a Split duration cam that opens the exhaust valve sooner before BDC Or maybe Advance the cam you have now even more then its 4* Maybe like 8* for a 105* ICL IMO even with boost a little bit of overlap scavenging isnt a bad thing. mike
