Re: How fast have you gone with a stock BB shortblock ? [Re: VT_Dart] #54677
02/19/10 12:15 PM
02/19/10 12:15 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I was always impressed with Zippy's low-budget build he had for awhile. That thing hauled for what it was.
Thanks, appreciate that
I just followed the Direct Connection 13.5 second combo as close as I could afford at the time, which meant I bought the recommended cam, but I skipped the good valve job and the cylinders were nowhere near straight or round
Flogging it for 13 years and knowing it really well helped alot too.
I don't know my current combo anywhere near that well, darned real life keeps getting in the way of testing...
Rich H.
Esse Quam Videri
Re: How fast have you gone with a stock BB shortblock ? [Re: moparniac] #54678
02/19/10 12:21 PM
02/19/10 12:21 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
how are you guys getting these big rollers in there with stock pistons? OP said completely stock bottom end like pulled right out of aold mope!
Stock pistons .150 in the hole helps alot with clearance
Sure they don't have any compression but the big cam fits fine
Re: How fast have you gone with a stock BB shortblock ? [Re: ZIPPY] #54679
02/19/10 12:41 PM
02/19/10 12:41 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Just last year my 67 Satellite still had the original 383 130,000 mile short block in it, and its orig. 516 heads with stock valves. It was a 2bbl motor, so in the 9:1 neighborhood. Wearing a holley 750 and an RPM intake, with a Delta .496 hyd. cam and a set of used headers, it went 13.73 @ 101. I flogged that 383 to 6400 RPM, and it never missed a beat. held 40 psi of oil pressure until the day it came out.
Re: How fast have you gone with a stock BB shortblock ? [Re: AlexP] #54680
02/19/10 12:54 PM
02/19/10 12:54 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Before, just a completely factory built OE shortblock.
I'd gone as quickly as 12.2s at 112 MPH in a 3700# car... until it threw a rod. Ya' can't trust those OEM rod bolts once they've had all those miles run up on them.
Re: How fast have you gone with a stock BB shortblock ? [Re: BradH] #54681
02/19/10 01:24 PM
02/19/10 01:24 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Also see the "stock smogger 440" thread in the best of/archives section.
Mine ran a 12.0 at 110 in a 64 dodge .. .528 cam.
Re: How fast have you gone with a stock BB shortblock ? [Re: moparniac] #54682
02/19/10 06:56 PM
02/19/10 06:56 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
My NOS rollers have 114 lobe sep.That helps a ton.The Max wedge heads are cut a mile.So it has some compression.
