Re: How fast have you gone with a stock BB shortblock ?
[Re: moparniac]
#54678
02/19/10 12:21 PM
02/19/10 12:21 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
how are you guys getting these big rollers in there with stock pistons? OP said completely stock bottom end like pulled right out of aold mope!
Stock pistons .150 in the hole helps alot with clearance
Sure they don't have any compression but the big cam fits fine ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: ZIPPY]
#54679
02/19/10 12:41 PM
02/19/10 12:41 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Just last year my 67 Satellite still had the original 383 130,000 mile short block in it, and its orig. 516 heads with stock valves. It was a 2bbl motor, so in the 9:1 neighborhood. Wearing a holley 750 and an RPM intake, with a Delta .496 hyd. cam and a set of used headers, it went 13.73 @ 101. I flogged that 383 to 6400 RPM, and it never missed a beat. held 40 psi of oil pressure until the day it came out.
[Re: AlexP]
#54680
02/19/10 12:54 PM
02/19/10 12:54 PM
BradH
Before, just a completely factory built OE shortblock.
I'd gone as quickly as 12.2s at 112 MPH in a 3700# car... until it threw a rod. Ya' can't trust those OEM rod bolts once they've had all those miles run up on them.
[Re: moparniac]
#54682
02/19/10 06:56 PM
02/19/10 06:56 PM
Posts: 1,256 Salisbury North Carolina
8secDart
My NOS rollers have 114 lobe sep.That helps a ton.The Max wedge heads are cut a mile.So it has some compression.
