Re: tti exhaust headers do not fit !!!! hits cuupler
[Re: hyefatman]
#546502
12/06/09 08:19 PM
12/06/09 08:19 PM
Posts: 8,586 Candler,NC / Myrtle Beach, SC
JDMopar
I just thought of something If Hemispherical Reproductions made your K frame out of a B-body core, your steering box sits at the wrong angle. B & E body k frames will physically bolt into either car and work with everything bone stock. But throw something like headers that might have a very close tolerance into the mix, and it could possibly cause the problems you are experiencing. In a B-body, the steering box points upwards to the rear at a greater angle than does an E-body steering box. I know it may sound like I'm taking up for TTI,which I'm not...I just wanted to give you more info that I thought of. Oh, and I'm 52...and know EXACTLY what you mean about headers back in the day! Good luck
[Re: hyefatman]
#546504
12/06/09 11:30 PM
12/06/09 11:30 PM
Posts: 6,516 Santa Cruz, California
Lefty
it also looks like the header is just touching the steering box --do i take a hammer to it
I would try and shift the engine 1st. Headers are always a pain, but worth the effort imo. I had to use a Dremel tool and grind some casting numbers off the side of my PS box to get my Doug's to fit rather than dent the head pipes. You need very little clearance on the drivers side because the engine torques away from everything.
[Re: Lefty]
#546505
12/07/09 12:33 AM
12/07/09 12:33 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
I put the TTI's on my 69 Dart with a 340 and had some minor clearance issues, so I made some 3/8 or 1/4 spacers (cant remember right off) to raise the motor up a little and that worked fine. You cant see them so it looks stock. Also I was told by a TTI rep. that not all stock K-frames are welded exactly the same so there might be some minor issues there also. Good luck!!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: hyefatman]
#546508
12/07/09 09:43 AM
12/07/09 09:43 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
ARE YOU USEING THE THE STOCK THROUGH BOLT ON THE DRIVERS SIDE ? If you want try this remove the drivers mount and buy a set of steel $14.00 mounts and install only the drivers side with a hardware store grade 5 though (long ) bolt in 5/8 inch size , this will cause the motor to be slightly higher on the drivers side and very strong also we have been running a 440 4speed b-body like this for years and also a 426 aluminum block hemi in a 71 challenger like this also no problems .
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#546509
12/07/09 09:49 AM
12/07/09 09:49 AM
Posts: 75,324 A gulag near you.
JohnRR
A gulag near you.
Do they make a solid mount for the HEMI sytle mounts ?
[Re: DennisH ]
#546511
12/07/09 10:01 AM
12/07/09 10:01 AM
JohnRR
A gulag near you.
OK. It's Monday. What does TTI say?
E-Body guys maybe should go to E-Body exclusive sites for advice. Seem to have more problems than B or others here. My B TTI's are fine. I'm just saying...
Is TTi even open yet? It's only 7 am on the LEFT COAST ...
I know EXACTLY what they are going to say ...
[Re: JohnRR]
#546512
12/07/09 10:08 AM
12/07/09 10:08 AM
Challenger 1
Cincinnati, Ohio
Me too.
[Re: Mr.Yuck]
#546516
12/07/09 06:27 PM
12/07/09 06:27 PM
Posts: 1,329 NC
DCM71cuda
NC
blah blah blah, for what they charge they should install themselves. for some they work great and for others not so much. The fact that the car or engine has dropped 1/32 of an inch shouldn't effect fit. I know 2 guys that bought complete kits that had huge fit issues. Jeesh I'd expect it form a $230 kit but not a $1000+ kit. Good luck, I hope they don't recommend swapping mounts, changing column and so on.
If they don't make/design them for a 'stock' installation, what else would they have to base the design on?
If your engine is not in a stock location, and your engine components are not in a stock location, how can you possibly blame tti for that??
Because if they fit nicely in your 'non stock' location, then they probably would not fit anything else.
[Re: DCM71cuda]
#546519
12/08/09 09:15 AM
12/08/09 09:15 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I don't know but I've used cheap headers and mid price headers on many BB B-bodys and have never had to dimple, ding or bend them. None of them dragged or had extensive leaks as many claim on this site. The thing you have to do is TAKE your time, get the motor up, steering column out and most fit pretty easy. for somebody to charger $6-700 for a set of headers is crazy. The 72 340 swinger I had had a set on it. Nice yes, but after 3 years of driving they looked like any other header out there. I put a set of Summit headers on my bro's 318 67 sat in about 30 minutes. (mani's off, engine up and column in the car. The fact that a car..or the cars engine has dropped a tad should have that much of an impact on your headers. I'm guessing from the factory they had a + / - on engine height.
