Re: Removing undercoating?
[Re: RalleyA12]
#54471
03/09/08 09:00 PM
03/09/08 09:00 PM
The way to do this is to use Gunk Engine De-greaser. Spray it into a contrainer and use a brush to work it into the undercoating.
Keep the area wet and use a poly tarp under the car. The undercoating will practically scrape off like butter.
I did my '66 Dodge Monaco this way, and I had previously tried all of the above mentioned methods, but none worked as good as this.
Brad 1966 Dodge MOnaco (Canadian Built)
[Re: SSAAHemiFan]
#54474
03/30/09 07:26 AM
03/30/09 07:26 AM
Challenger 1
Cincinnati, Ohio
Challenger1 , Is a hotsey the same thing as the steam pressure washer?
I beleive so... We used to have Hotsey hot box that we used for a few years.It was just a box that heated the water after the cold water pressure washer. But I think your talking the heated pressure washer with the vertical burner. Yes it should do the same thing. Please read these threads for a few tips.
Check out this thread: web page
