Re: Indy Legend or Stage 5?
[Re: REHBERGERRACING]
#544066
12/04/09 06:48 PM
12/04/09 06:48 PM
Are you guys going to race your pieces of paper? No one mentions E.T. or mph. Just flow #'s. Big deal!
#544067
12/04/09 09:05 PM
12/04/09 09:05 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
I gots me a .466+ lobe lift flat tappet from Barton that will go in first...Then a Old crane grind which has about .475 lobe lift roller. I say this cause i dont know what ration these rocker arms are, some say 1.6 some say less.
Compression is 14:1
Do i win a prize Dan-O for the largest flat tappet on the web site or something...
I guess it would be funny if I was running a .500 lift cam talking about all this flow.
well, if i was going to give you a prize for that flat tappet that'll end up around .755 lift, it wouldn't be anything to be proud of.
by the way, the S/R heads won't even come close to the power potential of the raised port big valve or millenium stage 5's.
the reason i asked about the cams and combo's is because the supposed 10 cfm difference doesn't amount to squat. until you build something of real potential, it's meaningless and not even worth worrying about.
for example, go ahead and run that silly flat tappet cam and somebody else running a well designed roller 10 degree's smaller with 10 less cfm will put you on the trailer. see my point?
Like mine
#544069
12/05/09 01:08 AM
12/05/09 01:08 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Ah but good flow numbers mixed with the right cam and engine combo will make the car faster...
#544071
12/05/09 10:52 AM
12/05/09 10:52 AM
Posts: 1,162 s e mich
ro23car
s e mich
ill be out there next year with ya
