How would you build a 518 trans for 550hp/torq? #543983
12/03/09 04:03 PM
12/03/09 04:03 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
How would you build a 518 to take 550hp/torq in my sig car. Assume 4000 pound car with drag radials. Would be a mostly street car with some strip. I'd say 90% street, 10% strip at most. Overdrive would be setup to run at low load/cruise levels only, not WOT. Not interested in putting power through the overdrive gear.
What parts would you use? I was thinking a good rebuild kit plus the transgo TFOD-HD2 shift kit. What other goodies would you use? Bands? Sprags? Other? Not looking for anything too exotic, engine rpm will not exceed 6000rpm. Any other mods that should be done?
I don't have a trans yet, however the 46RE's are readily available in the yards, the RH's seem to be a bit tougher to find around here. I would just have to go with which ever I could find first. I know tearing into the trans would tell of anything else that needs to be done, but I'm interested in what would have to be done right off the bat for this power level.
Also, I understand the normal 518's will run a 727 converter, but the lockup ones won't. Is there a decent source for lockup performance converters. Not interested in a ton of stall speed, 2700-3000 would be nice.
Re: How would you build a 518 trans for 550hp/torq? [Re: DaytonaTurbo] #543984
12/03/09 04:43 PM
12/03/09 04:43 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's not a lot of power for those trannies. You should be fine with a basic rebuild and a shift kit to change the pressures.
Get a 46RE for the upgraded internals and run the 46RH valve body.
- Stu Harmon
Re: How would you build a 518 trans for 550hp/torq? [Re: feets] #543985
12/03/09 04:52 PM
12/03/09 04:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think that is possible since the RE will not have the HYD gov circuit.
An RH or 518 shouldn't be hard to find , RE is 96 up , but he needs to decide if he wants lockup or not .
Build the OD section to Diesel V10 specs and you'll be fine , everything forward is a 727 , don't worry about the sprag , it's a much better piece in the OD trans , think it's 14 elements in a plastic holder for it and the springs . I broke my output shaft on the trans in my ram power braking against the convertor to build boost with the trans in drive , rear band not applied , didn't hurt it , truck was fixed at the dealer and they didn't do anything other than pull the OD unit to fix , left the trans in the truck .
Re: How would you build a 518 trans for 550hp/torq? [Re: DaytonaTurbo] #543986
12/03/09 05:11 PM
12/03/09 05:11 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Actually, you'll want the RH as it's the hydraulically controlled overdrive. The RE is electronically controlled overdrive requiring a computer to controll it.
Re: How would you build a 518 trans for 550hp/torq? [Re: Jwilli500] #543987
12/03/09 05:20 PM
12/03/09 05:20 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Well, looks like while I was waiting for my computer to unfreeze and send you got some better answers anyways. LOL
Re: How would you build a 518 trans for 550hp/torq? [Re: JohnRR] #543988
12/03/09 06:14 PM
12/03/09 06:14 PM
Manitoba, Canada
Manitoba, Canada
Okay I think I may have been a little confused, or at least I am now, lol. So the 95 and prior 518 with the 3-wire connector for overdrive/lockup is the 46RH? The 518 with the two-wire connector for overdrive and no lockup is also called the 46RH??
What does it take to build the OD section to diesel/v10 specs?
I'm just trying to compile a list of parts for now. I was checking out bulkpart.com and they've got most of what I think I need. They've got their performance rebuild kits for a bit over 200 bucks, 150 for the transgo shift kit for od trans.
Should I be doing anything else? Bands, accumulator or servo upgrades? Basically I want to put the parts on the shopping list that are going to get done either way, then add anything if there's more wrong with it when I tear it apart.
Thanks for the info and keep it comming.
Re: How would you build a 518 trans for 550hp/torq? [Re: DaytonaTurbo] #543989
12/04/09 06:50 PM
12/04/09 06:50 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
RH Lockup (95 and older) is 3 wire
RH Non Lockup (95 and older) is 2 wire
RE (96 and newer) is Multiwire
This is 518(727 based)only, the 500 is a whole nuther deal.
4 = # of forward gears
6 = level of service (strength) (5, 6, or 7)
R = Rear wheel drive
H = Type of over drive control (Hydraulic or Electronic)
I think it's the ATSG manual that has some pretty good info in it if you want to get started aquainting yourself with these trannys. Bulkpart has the manual and a video. I really like having a video. go to: http://www.bulkpart.com/Merchant2/mercha...Product_Count=1
Re: How would you build a 518 trans for 550hp/torq? [Re: JohnRR] #543990
12/04/09 07:02 PM
12/04/09 07:02 PM
bc canada
dbailey43 Offline
dbailey43  Offline
bc canada
put a 518 behind a healthy 440 with jvx adapter,had mopar trans guy go thru my trans and apparently not over do anything.355 gear and shift to OD squaks 60 series tires!!
Re: How would you build a 518 trans for 550hp/torq? [Re: dbailey43] #543991
12/04/09 09:00 PM
12/04/09 09:00 PM
Manitoba, Canada
Manitoba, Canada
Thanks for the info. For some reason at first I was thinking the RH was the 2-wire and the RE was the 3-wire. 2-wire or 3-wire which ever I can find at the yard. Not terribly concerned about the lockup. Yeah I saw the ATSG manual and video on there and I think I will pick up both of them. I'm sure I could manage it with just the manual but the video would probably be worth it. I plan to mate motor to trans with a jw ultrabell. The local u-pull should have the trans I need, will just have to make it out there before it gets too much colder outside.
Re: How would you build a 518 trans for 550hp/torq? [Re: DaytonaTurbo] #543992
12/04/09 09:11 PM
12/04/09 09:11 PM
canada
jneuf Offline
jneuf  Offline
canada
Better hurry! Is getting cold fast!
Good luck with the OD trans. That should be great for cruising.
Re: How would you build a 518 trans for 550hp/torq? [Re: DaytonaTurbo] #543993
12/04/09 09:40 PM
12/04/09 09:40 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
if thats the same VID i have its pretty lame
Re: How would you build a 518 trans for 550hp/torq? [Re: jneuf] #543994
12/04/09 09:50 PM
12/04/09 09:50 PM
Manitoba, Canada
Manitoba, Canada
Yeah not kidding, better get moving on this soon!
Well since I doubt there's more than one 518 video out there I have to ask in what way was it lame? Not much useful info and too much of a general overview? I just checked and that's video's not cheap. If it's crap I'll pass.
Re: How would you build a 518 trans for 550hp/torq? [Re: DaytonaTurbo] #543995
12/05/09 03:56 AM
12/05/09 03:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The RH trans will look like a normal 727 on the left side with the 3 wire neutral safety switch and will also have the 2 or 3 wire plug also. The RE trans will have a round style plug on the left side of the trans with 7 wires in it. I built the 727 in my 63 using all stock Mopar clutches and bands. Since I have worked for a Dodge dealer the last 24 years I have a few of the Mopar kits around. I added the bolt in over running clutch (sprag) and I use a TA reverse manual valve body. Other then the v/b and sprag all the internal trans parts are stock pieces and have been holding up fine in my mid 11 car. In fact the 727 in my boys Dart is built the same and I built it in 1996. It have never been apart as we just changed the converter when we switched the 383 to a 400. Of course you will have the overdrive on yours but if you only plan to run 11's or slower most of the stock internals will work fine. Ron
Re: How would you build a 518 trans for 550hp/torq? [Re: 383man] #543996
12/05/09 03:12 PM
12/05/09 03:12 PM
Manitoba, Canada
Manitoba, Canada
Anyone know if the 727 governor kits will work on the 518? The max wedge shifting thread got me thinking so I check out cope's website and he's got a nice variety of governor kits the rpm range I want.
Re: How would you build a 518 trans for 550hp/torq? [Re: DaytonaTurbo] #543997
12/05/09 04:51 PM
12/05/09 04:51 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
How are you going to fit it in your car? Tailshaft is huge.
I want my fair share
Re: How would you build a 518 trans for 550hp/torq? [Re: SomeCarGuy] #543998
12/05/09 05:36 PM
12/05/09 05:36 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
That was going to be my question. Especially with the isolated t-bar crossmember. That's what's scared me the most about trying this.... Make sure you take lots of pics!
Re: How would you build a 518 trans for 550hp/torq? [Re: James74] #543999
12/06/09 02:22 AM
12/06/09 02:22 AM
Manitoba, Canada
Manitoba, Canada
Yeah that's the last main hurdle I've got to work through. I do know it has been done on a 73-74 B body and I've messaged a guy I know who did it, hope he responds. I'm sure someone else on here did it, but the search has been changed to a max range of 1 year.
Re: How would you build a 518 trans for 550hp/torq? [Re: DaytonaTurbo] #544000
12/07/09 02:06 PM
12/07/09 02:06 PM
Manitoba, Canada
Manitoba, Canada
Well I exchanged a few messages back and forth with the guy who did this to his 73 charger. He didn't have to mod the isolated torsion bar crossmember however he did have to clearance the body crossmember that the isolated torsion bar crossmember bolts up to. However seeing that 1_WILD_RT has posted pics showing how to get a 518 under an e-body with some grinding of the transmission case, who knows, it may be possible for me to get it in without modding the upper crossmember or at least not modding it heavily. No doubt the hardest part is going to be lifting that transmission into place to check for clearance.
Re: How would you build a 518 trans for 550hp/torq? [Re: DaytonaTurbo] #544001
12/07/09 02:22 PM
12/07/09 02:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The diesel/V10 od has more clutches and steels in the direct clutch pack , that's inside the unit in the OD case (I can't remember now if I have an extra clutch and steel in there or just tighter clearance need to find my notes) and possibly more pinions in the planet ... not sure on that one but you should be fine with the gasser planet ... The big thing is the clutch and steel count , more cluthes is more holding power , it's also possible to put an extra clutch and steel in the OD clutch pack that is on the rear of the main case , but you have to machine the pressure plate like people have done to put 5 clutches in a 4 clutch drum with the thicker steels. These mods will hold upwards of 1000 plus lb/ft of torque .
Re: How would you build a 518 trans for 550hp/torq? [Re: JohnRR] #544002
12/07/09 03:13 PM
12/07/09 03:13 PM
Manitoba, Canada
Manitoba, Canada
Thanks for the info john, sounds like the overdrive and extra clutch mods are likely overkill for my plans for the car. Since I have no intention of putting a roll bar in the car I won't be going that fast down the strip with it. I seem to recall some mods having to do with enlarging the oil supply holes in the OD shaft. Is this worth looking into or can I just leave it as-is?
