Page 2 of 3 1 2 3
Re: Jesel or T&D Individual Shaft Rockers [Re: Ari440] #541963
08/19/14 02:50 AM
08/19/14 02:50 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
T&D paired 5/8" shaft rocker system and don't look back.
Money well spent!
Call T&D and ask for Sheldon, tell him Bob from Carson City told you to call.
T&D 1(775)884-2292
Re: Jesel or T&D Individual Shaft Rockers [Re: Ari440] #541964
08/19/14 02:51 AM
08/19/14 02:51 AM
Finland
LUMI Offline
LUMI  Offline
Finland
HOW MUCH MONEY ARE THE T/D AND JESSEL SETUP
Jersel 1685
T&D single shaft 1350
T&D paired shaft 1450
i ordered T&D single shaft 2 weeks ago from Koffels Place
Re: Jesel or T&D Individual Shaft Rockers [Re: dodgeboy11] #541965
08/19/14 02:54 AM
08/19/14 02:54 AM
Carson City, Nevada
Carson City, Nevada
Seriously, you could flip a coin on the rockers. Since you're in Oregon I'd consider T&D's just because if you do need parts, they're only a state and a half away from you.
Jason Nevada borders Oregon so we are only a state away.
What is wrong with you? Did you go to school in Lund Nevada or something?
JEEZZZ!
Re: Jesel or T&D Individual Shaft Rockers [Re: Biginchmopar] #541966
08/19/14 04:24 AM
08/19/14 04:24 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
I had Scott do the oiling and go through my motor a couple seasons ago and he set up mine with his standard rockers and trend pushrods, it worked good until when I freshened it I went to a stiffer spring then I started having rocker and pushrods problems. I went to a .130 wall 3/8" pushrods and Harland sharp single shaft rockers and had no more problems. I think the black standard rockers fatigue after a couple hundred runs. Harland sharp are $1200 complete any ratio. Poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Jesel or T&D Individual Shaft Rockers [Re: poppaj] #541967
08/19/14 04:59 AM
08/19/14 04:59 AM
Finland
LUMI Offline
LUMI  Offline
Finland
mine lasted about 12 runs on strip and 400 miles street
Re: Jesel or T&D Individual Shaft Rockers [Re: LUMI] #541968
08/19/14 09:14 AM
08/19/14 09:14 AM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
I'd like to see a pic of the T&D individual shaft set up installed. I've decided to sell my Jesel for my 440-1's stuff and look into possibly the T&D single shaft or the individual. Do the individual shaft rockers from T&D require milling off the rocker stands?
Steve
Photobucket sucks
Re: Jesel or T&D Individual Shaft Rockers [Re: 72chrgrally] #541969
08/19/14 11:25 AM
08/19/14 11:25 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
They do require machining. I have used both style T&D's, and both have worked well. Not so with the black Koffel's, not even after consulting with Koffel's and doing things according to their instructions. No need to get yourself aggravated, when it can be easilly avoided.
Plynouth VIP '67 TT IC EFI
Re: Jesel or T&D Individual Shaft Rockers [Re: jyrki] #541970
08/19/14 12:07 PM
08/19/14 12:07 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
One thing to remember with the single shaft setups. I know T&D recommends no larger than a 1.550 dia. spring. I don't know about Harland Sharp. I have used the individual shaft T&Ds on a few engines with pushrod oiling and never had an issue.
Re: Jesel or T&D Individual Shaft Rockers [Re: 72chrgrally] #541971
08/19/14 12:33 PM
08/19/14 12:33 PM
NC
440Jim Offline
440Jim  Offline
NC
Steve
Attached is a picture of the T&D rockers that have the paired shaft system (a short shaft for each cylinder). The rocker stands had to be milled off and the holes to bolt down the adapter added. Indy 440-1 CNC heads, setup by BEST Machine.
Re: Jesel or T&D Individual Shaft Rockers [Re: 440Jim] #541972
08/19/14 12:35 PM
08/19/14 12:35 PM
NC
440Jim Offline
440Jim  Offline
NC
And this picture is of one pair of rockers.
These are 1.65 ratio, and 1.62" dia springs.
Re: Jesel or T&D Individual Shaft Rockers [Re: 440Jim] #541973
08/19/14 01:37 PM
08/19/14 01:37 PM
NC
440Jim Offline
440Jim  Offline
NC
And this is a picture of the adapter that bolts to the head after milling off the cast rocker stands.
Re: Jesel or T&D Individual Shaft Rockers [Re: 440Jim] #541974
08/19/14 01:56 PM
08/19/14 01:56 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Thanks for the pics. It looks like the paired T&D's use the same mounting idea as the Jesel's that I already have. I'd really like to avoid machining off the rocker stands, I think if I was buying new I would have them machined off by Indy and ready to go but at this point I think I'll go with the single shaft deal from T&D. Part of the problem is finding someone up here that knows what is involved with doing the job, I don't want my heads being a guini pig for someone to learn on.
Steve
Photobucket sucks
Re: Jesel or T&D Individual Shaft Rockers [Re: 72chrgrally] #541975
08/19/14 03:09 PM
08/19/14 03:09 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Resurrected from the dead. Got to love someone using the search function
Re: Jesel or T&D Individual Shaft Rockers [Re: 440Jim] #541976
08/19/14 03:11 PM
08/19/14 03:11 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
And that's how it's supposed to be done!
Re: Jesel or T&D Individual Shaft Rockers [Re: 72chrgrally] #541977
08/19/14 03:52 PM
08/19/14 03:52 PM
AndyF Offline
AndyF  Offline
If you already have Jesel rocker arms and you just need the heads machined then send the heads and the arms down to Jesel and they'll take care of it for you. I'm sure there are plenty of other shops who can also handle the machine work. I machined my EZ heads for Jesel rocker arms but I had access to a good machine shop. I will say that it is better to order the heads from Indy with the Jesel machining rather than reworking single shaft heads. Doing the work once is much better than drilling and tapping holes that have already been drilled and tapped.
Re: Jesel or T&D Individual Shaft Rockers [Re: LUMI] #541978
08/19/14 05:01 PM
08/19/14 05:01 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Jersel 1685
Do you guys know how much hemi rockers cost? My wife didn't either until recently.
Re: Jesel or T&D Individual Shaft Rockers [Re: AndyF] #541979
08/19/14 05:21 PM
08/19/14 05:21 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Bringing parts across the boarder to be machined in the US can be a real PITA for us. I've heard horror stories, mostly about coming back across the boareder from the States. On top of that once they have been machined I would have to use Jesel stuff forever on them, I'd like to keep the versatility of keeping the single shafts. These heads may end up going onto another project we have when I build a 572.
I read your book Andy, thank you for writing it, extreamly informative!
Steve
Photobucket sucks
Re: Jesel or T&D Individual Shaft Rockers [Re: 72chrgrally] #541980
08/19/14 06:12 PM
08/19/14 06:12 PM
AndyF Offline
AndyF  Offline
You could take your heads up the 401 to Bewdley and have Tim at FHO do the machine work. I'm sure he can handle a Jesel conversion and you won't have to cross the border.
Re: Jesel or T&D Individual Shaft Rockers [Re: AndyF] #541981
08/20/14 08:54 AM
08/20/14 08:54 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
That would only be 1 1/2 hours drive for you Steve.
Re: Jesel or T&D Individual Shaft Rockers [Re: Al_Alguire] #541982
08/20/14 09:24 AM
08/20/14 09:24 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
we got some homework to do !
1.39 9.85 - 137 mph
Page 2 of 3 1 2 3
