Page 2 of 3 1 2 3
Re: Shifter preference for street and strip,reverse manual [Re: BSB67] #541874
12/01/09 09:29 PM
12/01/09 09:29 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
I'm interested to know if anyone uses any of the PPP shifters for a street/strip car?
Re: Shifter preference for street and strip,reverse manual [Re: Chad Bittle] #541875
12/01/09 10:02 PM
12/01/09 10:02 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
i got the idea for this shifter from Ryan Johnson..I fell in love with it, they work great with reverse pattern valve bodies. I had a few guys help run one down for me..
This thing will give my car the Hemi ca the look I am after...
Hurst Lightning rod shifter
They can be found on ebay but the carry a high price tag...Well as a matter of fact a fully loaded PPP shifter can be had cheaper in some case..
I seen a NOS one go for $1k
Re: Shifter preference for street and strip,reverse manual [Re: Bob_Coomer] #541876
12/01/09 10:33 PM
12/01/09 10:33 PM
Pewaukee, WI
Airgrabber Offline OP
Pewaukee, WI
Looks like the B&M Pro Ratchet is the most popular choice here. The black stealth unit is sweet looking as well. I guess I should give up the idea of trying to save my stock console now that I'm dipping into the 11's. Next thing is some decent slicks.
Re: Shifter preference for street and strip,reverse manual [Re: Airgrabber] #541877
12/01/09 10:43 PM
12/01/09 10:43 PM
PA
moparacer Offline
moparacer  Offline
PA
Cheetha has no equal on the Strip.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.44-126
414 cid SB Dragster 7.65-174
Re: Shifter preference for street and strip,reverse manual [Re: Airgrabber] #541878
12/01/09 10:45 PM
12/01/09 10:45 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Pro Stick is what I have now and have used in the past, but probably won't work with a clean neutral tranny, so may have to go with a PPP.
Steve
Photobucket sucks
Re: Shifter preference for street and strip,reverse manual [Re: 72chrgrally] #541879
12/01/09 11:22 PM
12/01/09 11:22 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Pro Ratchet here.
Re: Shifter preference for street and strip,reverse manual [Re: hemi-itis] #541880
12/01/09 11:52 PM
12/01/09 11:52 PM
Fitchbug, Mass.
WannaRunner Offline
WannaRunner  Offline
Fitchbug, Mass.
My preference
WOW! thats not a Red, Yellow, Green car. its more like 10.... 9..... 8..... 7.....
Re: Shifter preference for street and strip,reverse man [Re: Chad Bittle] #541881
12/02/09 01:23 AM
12/02/09 01:23 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I have a PPP in my street/strip Duster.. I freakin love it at the track!! never missed a shift yet.. On the street, it works good, the reverse lock-out takes a bit to get used to... but very easy to overcome..
Also, its a great conversation piece as many people have never seen one and want to know all about it..
Re: Shifter preference for street and strip,reverse manual [Re: BSB67] #541882
12/02/09 10:19 AM
12/02/09 10:19 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Don't you just leave it in "D"?
Fastback Charger with column shift? Interesting, and cool.
Re: Shifter preference for street and strip,reverse manual [Re: Airgrabber] #541883
12/02/09 10:50 AM
12/02/09 10:50 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I can tell you what I don't like!
I'd stay away from a Hurst Quarter Stick
It's real easy to go from 1st to 3rd if you don't pull the lever in properly And it's a long throw back to 3rd from 2nd.
I'm paying close attention for everyones opinion also but I have a reverse manual and wan't to be able to smack the thing from 1st to 2nd without having to jump through any hoops.
Then be able to go from 3rd to nutral after I slow down a bit after the stripe.
Hope I dind't highjack the post!
Re: Shifter preference for street and strip,reverse manual [Re: roadhazard] #541884
12/02/09 11:06 AM
12/02/09 11:06 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I use a JVX, made by Winters I think.
Re: Shifter preference for street and strip,reverse man [Re: Jeepmon] #541885
12/02/09 11:14 AM
12/02/09 11:14 AM
Monroe,Connecticut
BigEdsGarage Offline
Monroe,Connecticut
I run a PPP in my car also. It's the only shifter I will ever use from this point on. It exceeded all my expectations in quality and performance..and the support is great! Nearly impossible to miss a shift of select the wrong gear. Detented gates, spring loaded, just push or pull the lever each shift. Reverse pattern or regular, front or rear cable exit, reverse lock out, trans brake and or line lock switch on the handle, neutral safety switch wiring, air shifted if you want, just many of the features...it is by far the most versatile shifter out there and performs flawlessly. Some deep aluminum tranny pans may require the cable bracket be modified. I just got mine from CRT already milled...fit perfect as it was shipped.
None of that stupid pull the trigger on one shift but not the other, make sure you move the lever sideways before the next shift..bla,bla,bla stuff that are design flaws with other shifters IMO. Straight forward or back on each shift and a super solid engagement...you know it is in gear!
Downshifting requires the trigger be pulled separately for each gear change so going back to first requires 2 gate changes, but once you are used to it you can almost work it in one movement. Reverse requires the trigger and top thumb button on the handle to be depressed...as mentioned, a little tricky at first, but there is no way you are hitting reverse by accident.
I would highly recommend the PPP for street or strip use
Re: Shifter preference for street and strip,reverse manual [Re: ProSport] #541886
12/02/09 11:41 AM
12/02/09 11:41 AM
madison, ohio
modified1090 Offline
madison, ohio
Pro Ratchet here.
These B&M Pro Ratchet automatic shifters have the style and quality for professional racing, along with easy ratchet action. The Pro Ratchets have an NHRA/IHRA-approved reverse lockout that can be operated with one hand, a neutral safety switch, and a backup light switch. They work with both forward and reverse pattern valve bodies and most 3 and 4-speed transmissions. Compatible with CO2 and electric shifters, these shifters include a brushed aluminum cover and a 5 ft. Super Duty race cable.
the brushed aluminum cover looks nice as it is or can be painted to match interior. summit has them for $190
Re: Shifter preference for street and strip,reverse manual [Re: modified1090] #541887
12/02/09 12:02 PM
12/02/09 12:02 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
I just installed a B&M Stealth Pro and like it a lot. I have only had Winters in the past but the stealth is well built. Sorry the pic is so dark.
'71 Duster
Re: Shifter preference for street and strip,reverse manual [Re: Thackdaddy] #541888
12/02/09 03:36 PM
12/02/09 03:36 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
anything ratchet.
Re: Shifter preference for street and strip,reverse manual [Re: roadhazard] #541889
12/02/09 04:44 PM
12/02/09 04:44 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Me too!
If you like drag racing, support your local track.
Re: Shifter preference for street and strip,reverse man [Re: Jeepmon] #541890
12/02/09 04:44 PM
12/02/09 04:44 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
I'd rather it be a little tricky then easily go into reverse, haha. Thanks for the info, good to know before forking out the money.
Re: Shifter preference for street and strip,reverse man [Re: Chad Bittle] #541891
12/02/09 05:02 PM
12/02/09 05:02 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Two more things.. the PPP is completely a one handed operation.. everything is done with your thumb and fingers..
Also when driving on the street, hearing the clicks as you go from one gear to the next, there is no mistaking that you're in a race car..
Re: Shifter preference for street and strip,reverse manual [Re: 72chrgrally] #541892
12/02/09 06:07 PM
12/02/09 06:07 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Steve
Although I've never tried it I belevie the Pro atchet can be used for a clean nuetral VB. Just set it up like you would 4 speed and it should go P R N 1 2 3 N
Re: Shifter preference for street and strip,reverse manual [Re: Airgrabber] #541893
12/02/09 06:57 PM
12/02/09 06:57 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
You don’t have to give up the stock counsel just because you’re in the 11’s. I run mid 11’s with this. It’s a Hurst Promatic. I have a reverse manual VB.
Page 2 of 3 1 2 3
