Page 1 of 3 1 2 3
I may be in hot water #540853
11/30/09 02:57 AM
11/30/09 02:57 AM
fullmetaljacket Offline OP
I may be in hot water with my new Best built Big block.
I forgot to turn on my electric fans tonight while driving and when I come to look at the gauge, it is reading 230 degrees. Did I fry the motor? It seems okay and starts up normal. It was probably only for 5-10 minutes before I noticed.
I turned it off very quickly then started it again with the fans on full swing and the temps went down pretty fast to 180.
That's what I get for being pre-occupied with peoples junk talk and needs. No More Mr.Nice guy.
Re: I may be in hot water [Re: fullmetaljacket] #540854
11/30/09 03:04 AM
11/30/09 03:04 AM
Renton Washington
Triple Threat Offline
Renton Washington
230 is NOTHING. You're fine.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: I may be in hot water [Re: Triple Threat] #540855
11/30/09 03:29 AM
11/30/09 03:29 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yup. I wouldn't worry about 230. Mines spiked up to 250 before when I was tossing belts while figuring out a pulley alignment issue, and I haven't had any problems
**Photobucket sucks**
Re: I may be in hot water [Re: fullmetaljacket] #540856
11/30/09 08:19 AM
11/30/09 08:19 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Why have the fan on a switch?
Re: I may be in hot water [Re: Triple Threat] #540857
11/30/09 09:52 AM
11/30/09 09:52 AM
Az
Crizila Offline
Crizila  Offline
Az
Been there a few times on the return road after tossing belts. Made a full pass at the Columbus nats with no belts ( dumped them during the burn out ). 250 on the gauge. No damage. It is a good case for running a little higher octane fuel than you really need though.
Fastest 300
Re: I may be in hot water [Re: Crizila] #540858
11/30/09 12:18 PM
11/30/09 12:18 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
my heat gauge goes to 320 and ive peged it past that,no aparent damage.
Re: I may be in hot water [Re: bonefish] #540859
11/30/09 12:24 PM
11/30/09 12:24 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
you just gotta watch that kinda heat kills valve springs..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: I may be in hot water [Re: fullmetaljacket] #540860
11/30/09 12:53 PM
11/30/09 12:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s just a spike pressure reading if it dropped to 180......done it a few times myself w/out any issues.
Re: I may be in hot water [Re: fullmetaljacket] #540861
11/30/09 03:05 PM
11/30/09 03:05 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
get a adjustable rheostat fan kit, it will turn fan on/off where you set the temp too, and can place a switch inline( out of the way ) so if you go drag racing you can turn it off during a run.
if you have two fans you can set one to come on at a set temp, and turn one on with a switch when needed.
most cars/trucks run 210-220 so 230 no big deal.
Re: I may be in hot water [Re: Sub95] #540862
11/30/09 04:15 PM
11/30/09 04:15 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I have an on/off switch for my electric fan, but I also bought a fixed controller that will kick on at 205, just in case we get pre-occupied and forget to turn it on...
Re: I may be in hot water [Re: Challenger 1] #540863
12/04/09 01:03 AM
12/04/09 01:03 AM
I like to turn it off just before a run so that my MSD, Fuel pumps get all the juice they need. When I turn it on after a run, you can hear and see the draw of the fans through the gauges and lights. They work crazy well. From a 97'Dodge Caravan.
Re: I may be in hot water [Re: fullmetaljacket] #540864
12/04/09 01:42 AM
12/04/09 01:42 AM
I had a fuse blow on my electric water pump at the World finals years years ago, the motor got up to 250 F before we got back to the truck to fix it. The stupid thing ran faster after that That was back when I use to set the ring end gap up tight, .014 to .016 on top (4.250 bbore) and .010 to .012 on the second ones 230F won't hurt the motor unless you have the ring end gap really tight
Re: I may be in hot water [Re: fullmetaljacket] #540865
12/04/09 09:42 AM
12/04/09 09:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
230 is nothing.... during road testing for Chrysler
we would do hot soaks and the injectors would normally
see 250 and more seating there with the engine off
before it started to cool
Re: I may be in hot water [Re: MR_P_BODY] #540866
12/04/09 02:29 PM
12/04/09 02:29 PM
Thanks guys. I'm sleeping more tonight.
Can't wait till next season.
Re: I may be in hot water [Re: fullmetaljacket] #540867
12/04/09 03:42 PM
12/04/09 03:42 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Maybe you need a light to remind you, or a string on your finger to remind you to turn it on, LOL I didn't know the season was over, its just about to start for me.
Re: I may be in hot water [Re: B1KILLER] #540868
12/04/09 05:41 PM
12/04/09 05:41 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Keep rubbin' it in Alex Your just a summer,fair weather friend
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: I may be in hot water [Re: hemi-itis] #540869
12/04/09 06:37 PM
12/04/09 06:37 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I have a warm spot for all you guys up north
Re: I may be in hot water [Re: MR_P_BODY] #540870
12/04/09 10:14 PM
12/04/09 10:14 PM
Yeah, It feels like the motor just shrugged it off and is performing as well as ever.
I just never went that high to the ceiling with the temps. This motor runs pretty cool even on Summer days and eves.
Re: I may be in hot water [Re: B1KILLER] #540871
12/04/09 10:22 PM
12/04/09 10:22 PM
hemi-itis Offline
hemi-itis  Offline
Well,,,,,,,,,,,,,at least keep the pic's commin so we have sumptin to look as when we're done cleaning the snow
Re: I may be in hot water [Re: hemi-itis] #540872
12/05/09 01:05 AM
12/05/09 01:05 AM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
Drove my car in 110 heat from Wi to Monster Mopar weekend and pegged the thermostat at 230. Was worried as you were but after we stopped for a while and had a few 's it was right back down to 180 with no problem.
Page 1 of 3 1 2 3
