Page 2 of 3 1 2 3
Re: Velocity - Timing ??????? [Re: Cab_Burge] #539970
11/29/09 04:16 PM
11/29/09 04:16 PM
Q
Quicktree Offline OP
Q
What's your total timing? I agree with some others on here. Small cubic inches, big heads and intake and that's causing the issues you're describing. I'd consider locking in the timing at 35 and either having a the starter switch separate from the ignition or running an ignition with a start retard.
yep thats an option, going to jack it up some more
Do all three carbs have rear jet extensions? Does it bog anytime you open the secondary or only when foot braking it and then hitting the throttle to WOT? I have had carbs. that would bog when to rich, with to much squirter and also when to lean and to small of squirters Keep expermenting and let us know what you find. BTW, I have never tumed a race car that was racing in weather that had more then 40 % humidity except just before and right after a thunderstorm
yes they all have extensions. it hesitates before the car moves. I think it's more of a timing issue now. they guys are saying it may need more with these heads.
Re: Velocity - Timing ??????? [Re: Quicktree] #539971
11/29/09 04:24 PM
11/29/09 04:24 PM
I use a set of real weak springs in all of my distributors so the timing is all in by 1500 RPM of lower depending if I strectch them or not Good luck, keep looking
Re: Velocity - Timing ??????? [Re: Quicktree] #539972
11/29/09 04:25 PM
11/29/09 04:25 PM
Re: Velocity - Timing ??????? [Re: Cab_Burge] #539973
11/29/09 04:47 PM
11/29/09 04:47 PM
Q
Q
mine is set up like that and I just checked it again. it's in so quick I doubt now that is the problem but I will lock it out just to be sure.
Re: Velocity - Timing ??????? [Re: Quicktree] #539974
11/29/09 04:48 PM
11/29/09 04:48 PM
How about fuel sloshing out of the vent tubes into the carb on the hit?
Re: Velocity - Timing ??????? [Re: Quicktree] #539975
11/29/09 04:50 PM
11/29/09 04:50 PM
Az
Crizila Offline
Crizila  Offline
Az
Depending on how efficient your combustion chamber is, 35 degrees may be too much lead. Try setting the total @ 30 and see if that helps. Obviously with a 5200rpm convertor you aren't on the curve anymore when you launch - right???
Fastest 300
Re: Velocity - Timing ??????? [Re: Cab_Burge] #539976
11/29/09 04:51 PM
11/29/09 04:51 PM
Q
Q
nope like I said it's doing it before the car moves an inch. it iwll do it at idle
Re: Velocity - Timing ??????? [Re: Quicktree] #539977
11/29/09 05:07 PM
11/29/09 05:07 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
I had a problem similar to yours last year. I have a 1050 Quickfuel card 4 corner idle. I was adjusting the idle with the front two barrels. The car would pause ( not bog) when I would smash it of the line. Than I adjust the idle per instructions , with all idle air screws. 1 turn with the front idle screw , 2/3 turn with the back. problem went away
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Velocity - Timing ??????? [Re: caper] #539978
11/29/09 06:15 PM
11/29/09 06:15 PM
Q
Q
they were out 1 turn each from quickfuel. I turned the frons out an aditional 1/2 turn
Re: Velocity - Timing ??????? [Re: Quicktree] #539979
11/29/09 06:24 PM
11/29/09 06:24 PM
SoCal
Brian Hafliger Offline
SoCal
That could be part of the problem. Most of my holley's work best (foot braking)with the idle mixture screws out 2-2 1/2 turns. This helps the transition from idle to WOT. Some builds have required 3 turns out just to get past a bog with NO load on the engine!
Did they modify the idle ports or change the idle bleeds from holley?
Brian Hafliger
Re: Velocity - Timing ??????? [Re: Brian Hafliger] #539980
11/29/09 06:27 PM
11/29/09 06:27 PM
Q
Q
I am not sure Brian i'll run out and get the card. I had the other carb out 2 1/2 turns. I should have turned them out but forgot about it.
Re: Velocity - Timing ??????? [Re: Quicktree] #539981
11/29/09 06:30 PM
11/29/09 06:30 PM
Q
Q
ok idle air bleed is 70s
hi speeds are 32s main jets are 86 square squirters wer 33 front 35 rear from the factory with pink cams
Re: Velocity - Timing ??????? [Re: Quicktree] #539982
11/29/09 06:40 PM
11/29/09 06:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You need more motor.......... Back at ya!
Re: Velocity - Timing ??????? [Re: Thumperdart] #539983
11/29/09 06:42 PM
11/29/09 06:42 PM
Q
Q
no doubt
Re: Velocity - Timing ??????? [Re: Quicktree] #539984
11/29/09 07:08 PM
11/29/09 07:08 PM
UK
602heavy Offline
602heavy  Offline
UK
Turn the idle screws out another turn & go try it.
Re: Velocity - Timing ??????? [Re: 602heavy] #539985
11/29/09 08:30 PM
11/29/09 08:30 PM
caper Offline
caper  Offline
With a four corner idle carb ,it is important to adjust the idle on both primary and secondary idle speed screws. Lets say the engine is idling at 800 rpm and you want it to idle at 1100 rpm. You adjust the primary up 200 rpm , the secondary up 100 rpm to get your 1100 rpm.
Idle Speed Screws
Start out by putting a small piece of plain writing paper (.003) between the throttle butterfly adjusting screws (Idle speed screws) and the stops, let the throttle close, now back off (counter clockwise) the idle screw until you can just slide the paper out, now go back in (clockwise) 1 turn on the primary and 1/2 turn on the secondary. To start with anyhow, we want the primary and secondary idle speed screws to be set 1/3 - 2/3rds. The primary end of the carb is designed for idle and light cruise so it only makes sense that we should set the carb up using mostly the primary end circuits to accomplish a good idle
Re: Velocity - Timing ??????? [Re: Quicktree] #539986
11/29/09 08:32 PM
11/29/09 08:32 PM
SoCal
SoCal
Try 2 1/2 turns out and 35's square to start...
Brian Hafliger
Re: Velocity - Timing ??????? [Re: Quicktree] #539987
11/29/09 08:42 PM
11/29/09 08:42 PM
just pulled the car out of the trailer and fired it up. timing is setting at 20* at idle. thought that should be plenty but maybe I need to jack it up more. any thoughts?
Since you've tried 3 different carbs, like others have already mentioned, I bet it needs more initial timing........and that motor will probably want to be locked out with that much cam and all those cubes....
If that doesn't fix it, it obiously needs more fuel.......
Re: Velocity - Timing ??????? #539988
11/29/09 10:34 PM
11/29/09 10:34 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
how much vacuum do you have at idle? a 340 I had did the same thing, found out I only had 3 inches at idle. played with it to get 9, problem gone. just a thought.
Re: Velocity - Timing ??????? [Re: Quicktree] #539989
11/29/09 11:07 PM
11/29/09 11:07 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Fully ported 360-1 on a 360 might just have a weak signal
at the carburetor at idle. (Lazy)
Page 2 of 3 1 2 3
