Page 3 of 3 1 2 3
Re: Velocity - Timing ??????? [Re: S/ST 3040] #539990
11/30/09 05:23 PM
11/30/09 05:23 PM
Q
Quicktree Offline OP
Q
Fully ported 360-1 on a 360 might just have a weak signal
at the carburetor at idle. (Lazy)
I am sure
Re: Velocity - Timing ??????? [Re: Quicktree] #539991
11/30/09 05:27 PM
11/30/09 05:27 PM
Q
Q
heres the plan, going to put the red bushing in the distributor. that will jack the timing up to 28 at idle. even though I don't think thats the problem at this point. it sets at 20 at idle but it's all in at 38 before 2000 rpm. but it could be . going to put blue pump cams in the carb and reduce the squirters and see what happens.
Re: Velocity - Timing ??????? [Re: Quicktree] #539992
11/30/09 07:43 PM
11/30/09 07:43 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
for that little of a difference I would just lock it out. no real reason not too
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Velocity - Timing ??????? [Re: dusturbd340W5] #539993
11/30/09 08:51 PM
11/30/09 08:51 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Quick, just a thought, annular boosters work good for big heads on small cubes
Page 3 of 3 1 2 3
