Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53984
02/26/08 11:47 PM
02/26/08 11:47 PM
USA
CrAlt Offline
CrAlt  Offline
USA
Does AMD have a website?
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: 68-70 b-body outer wheelhouses [Re: CrAlt] #53985
02/27/08 12:44 AM
02/27/08 12:44 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
AMD Auto Metal Direct 866-591-8309 www.autometaldirect.com
Re: 68-70 b-body outer wheelhouses [Re: hemicar1971] #53986
02/27/08 01:25 AM
02/27/08 01:25 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
"I recently ran into major problems trying to use Goodmark's "Authentic Reproduction" Dodge B-Body outer wheelhousings on my 1969 Charger 500"
What a joke. Mopar isn't worried that your part wont fit, they just want money from royalties paid by suppliers that want that "Authentic Reproduction" wording on their product. Heck, they probably dont even know what a wheelhouse is The AMD stuff I have used is awesome and is a great addition to our hobby.
Re: 68-70 b-body outer wheelhouses [Re: Paul Jacobs] #53987
02/27/08 06:36 AM
02/27/08 06:36 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
xs29j8, Thanks for posting all that. Some of us that don't do a car a year would never notice those things until it was too late.
I can't afford this. mark
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53988
02/27/08 08:16 PM
02/27/08 08:16 PM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
Wow!Thanks for all the info XS.Im already on the list for their quarters.I called AMD today and told them to mark me down for a set of wheelhouses.Somebody replaced the trunk about 10 years ago and still looks good.The pictures of that trunk make me almost want to rip mine out and install the one piece.
Re: 68-70 b-body outer wheelhouses [Re: a12superbee] #53989
02/27/08 10:39 PM
02/27/08 10:39 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
I hope the information does help someone, but this episode cost me a lot of $$$ which Goodmark is so far not stepping up to the plate to reimburse...
In addition to almost $300 for the outer wheelhousings (incl shipping), there is the body shop labor to install & remove the incorrect parts... about $450.
There are other expenses as well, and to fix the problem I had to use a wheelhousing intended for my Six Pack Charger... So now I have to find a replacement for that one.
Here is the used wheelhousing being removed from the '70 quarter panel:
XS
Re: 68-70 b-body outer wheelhouses [Re: 70RT Charger] #53990
02/27/08 10:50 PM
02/27/08 10:50 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
I plan to send more pictures to AMD to show the problems encountered with the Goodmark "repro" parts, but I believe that they are going to get them right. Unlike the "Better Than Nothing" vendors, they actually do first First Acticle Inspections and test fits...
They final verdict will be known when the parts that I am getting from them are installed, but so far they have been a great company to work with... anf the trunk floor looks sooooo nice!
It was well packaged also...
XS
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53991
03/14/08 07:46 PM
03/14/08 07:46 PM
Toronto,Canada
W
wkeggenhoff Offline
wkeggenhoff  Offline
W
Toronto,Canada
can you install the 1 piece trunk floor with quarters still on the car ?
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
Re: 68-70 b-body outer wheelhouses [Re: wkeggenhoff] #53992
03/15/08 01:29 AM
03/15/08 01:29 AM
Yes a one piece trunk floor can be installed with the 1/4's still on.I have done it.On a Charger,it can be done by removing the rear valance panel[which a Charger usually needs anyway],and removing the tailpanel which is actually easy on a Charger since it is welded on top of the 1/4's ends not under like other cars.
I have installed the repro outer wheelhouses several times on B bodies.They are a real dissapointment.They look great until you try to fit them and they are way off.
They fit much better if you leave the original pinchweld intact at the outer/inner wheelwell seam and splice the new outer about 1/2 inch on the outside of the pinchweld.That way you can adjust the position and don't disturb the original inner to outer pinchweld which is a continuous resistance weld.Plug welding the repro outer to the original inner opens up leakage issues.From what I have seen,AMD's panels all look way better than Goodmarks.
Re: 68-70 b-body outer wheelhouses [Re: wkeggenhoff] #53993
03/25/08 05:13 PM
03/25/08 05:13 PM
O
OLD318 Offline
OLD318  Offline
O
A better question is:
Can you install or at least "GET" the 1 piece trunk floor from AMD into the trunk
with only the trunk lid removed?
or do you "Have" to remove the tailpanel?
Or as another option...
Could you "get" the 1 piece trunk floor (from AMD)
into the trunk with the trunk removed and 1 quater panel removed...
or do you have to remove the tailpanel as well?
inquiring minds want to know!!!
Re: 68-70 b-body outer wheelhouses [Re: OLD318] #53994
03/29/08 10:42 AM
03/29/08 10:42 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Removing the taillight panel is definitely the best way to go, although a "side entry" approach might be possible if some of the backlight area supporting structure was dis-connected.
The picture below should show the problems with that approach...
XS
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53995
03/29/08 10:52 AM
03/29/08 10:52 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
The AMD trunk floor has been test fitted in my Charger 500 with great results & no problems so far. Waiting on AMD repro rear valance and trunk floor extensions for final fit-check.
BTW, the drip-trough was completely cut through by Creative Industries during their modification of the car to a Charger 500 "Aero Car", so with the quarter panels removed the drip-trough is two seperate pieces... The part being bent to pivot the taillight panel down like a tail gate is only the rear valance which is totally rusted out and will be replaced when the AMD repro is available. Pivoting the taillight panel back down to its correct location allows for a better test fitting of the quarter panels & trunk floor than if it was totally removed (which WILL occur later). No parts have been cut or bent that will remain with the car...
XS
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53996
03/29/08 10:54 AM
03/29/08 10:54 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Another picture...
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53997
03/29/08 10:56 AM
03/29/08 10:56 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
One more...
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53998
03/29/08 10:59 AM
03/29/08 10:59 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Well, one more again... the fit to the wheel well housings seemed very good, but I will take a closer look on my next body shop visit...
XS
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53999
03/29/08 12:42 PM
03/29/08 12:42 PM
Jacksonville, Fl
426runner Offline
426runner  Offline
Jacksonville, Fl
Same work required here. Really slowed down the installation
Lip needed to move in-
Lip moved in-
Lip needed to move up-
Lip moved up-
Pie cuts required-
If I had it to do again I would leave the original lip attached to the car and splice in just enough of the new outerhousing as I needed, aligning the lip in the right place from the start.
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: 68-70 b-body outer wheelhouses [Re: 426runner] #54000
03/29/08 06:04 PM
03/29/08 06:04 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Great thread guys.
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #54001
04/04/08 09:58 AM
04/04/08 09:58 AM
eastern,Ky
eastern,Ky
Another view...
Looks like the AMD outer wheel houses are going to have the foward flange on it according to the pics.
Re: 68-70 b-body outer wheelhouses [Re: 70RT Charger] #54002
04/04/08 01:45 PM
04/04/08 01:45 PM
O
OLD318 Offline
OLD318  Offline
O
Are the AMD 68-70 B-Body outer wheelhouses
thicker than the Goodmark outers?
a couple of quick questions??
1)
If you have both quarter attached to the car
and you remove the trunk lid and then the entire
tailpanel...
What are you doing to support the end of the car?
2) If you then cutoff both quarter panels..
What is/are your reference point(s) for re-assembly? are you just sighting it down..?
Or, are you taking point to point measurments with a tram guage?
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #54003
07/18/08 06:40 PM
07/18/08 06:40 PM
eastern,Ky
eastern,Ky
Here is another angle showing the mis-match before the black color was removed by plastic media blasting...
XS
I got tired of waiting on AMD for my wheelhouses so I ordered a set from the paddock and they almost look like the originals,they look nothing like ones you show but they still look like they are going to fit crappy.
