Re: 68-70 b-body outer wheelhouses
[Re: 70RT Charger]
#53965
02/24/08 04:48 PM
02/24/08 04:48 PM
Posts: 603 Mass
charge70
Mass
The inner wheel houses are the same Charger to Coronet 2 dr or 4 dr.Charger and Coronet 2 dr outers are the same,but 4 dr Coronet outers are different.I checked the part#'s in the book and this is what I came up with. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: 70RT Charger]
#53967
02/25/08 12:53 AM
02/25/08 12:53 AM
Posts: 9,887 USA
CrAlt
USA
does anyone repo the inner and outer for 69 coronet 2dr?
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
[Re: 70RT Charger]
#53972
02/26/08 11:08 AM
02/26/08 11:08 AM
Posts: 4,764 near Port Huron, MI
Paul
near Port Huron, MI
I bought a set of rust free complete inner and outer wheelhouses off of a 68 4-door coronet after being told they would work on my charger.After looking at them the inners look the same but the outers looks like the lip might be about a inch lower than my chargers,I cant hardly tell because mine are rusted out.Can anybody please confirm if they are or are not the same.Thanks
all 68-70 b-body 4-door outer wheelhouses are the same as a Plymouth b-body two door. The inners are the same for all. Coronet 2-doors and Charger share the same outers.
[Re: Paul]
#53973
02/26/08 01:28 PM
02/26/08 01:28 PM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
I recently ran into major problems trying to use Goodmark's "Authentic Reproduction" Dodge B-Body outer wheelhousings on my 1969 Charger 500. I believe the same parts are sold by other vendors as well.
To read about the differences and other problems that I encountered check out my restoration thread starting at post #514...
http://www.dodgecharger.com/forum/index.php/topic,33799.510.html
I would get used wheelhousings or wait for AMD's repros...
XS
[Re: xs29j8]
#53983
02/26/08 08:41 PM
02/26/08 08:41 PM
xs29j8
Fort Worth, Texas
The AMD trunk floor seems to have all the cutouts & holes... even the screw holes for attaching the filler tube seal! Also, the metal sheet thickness seems to be correct or at least very near to the original... not half as thick like some repro sheetmetal parts are! XS
