Re: Engine Builders: How come no one runs a 1.7 rocker? [Re: Brian Hafliger] #536742
11/26/09 05:36 PM
11/26/09 05:36 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Anytime I run TD's on Mopars, I use 1.7 unless I can get more. Small block and Big block!!
Those sure are pretty..... do they run a needle bearing like the harlands ???
Mopar Performance
Re: Engine Builders: How come no one runs a 1.7 rocker? [Re: moparniac] #536743
11/26/09 06:01 PM
11/26/09 06:01 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Many of the stock Hemi rockers came in 1.5,1.6 and 1.7 since the early 80s,most all our current builds for Hemi and wedge use 1.6 or 1.7.,this is more the norm than the standard 1.5
Re: Engine Builders: How come no one runs a 1.7 rocker? [Re: B G Racing] #536744
11/26/09 06:17 PM
11/26/09 06:17 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
I have a set of 1.75 iron rockers on my 440
Re: Engine Builders: How come no one runs a 1.7 rocker? [Re: wyldebill] #536745
11/26/09 11:15 PM
11/26/09 11:15 PM
Renton Wa
topfueldart Offline OP
Renton Wa
Well I guess they are a bit wider used then I first suspected, which is a good thing. I appreciate the responses.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
