Cutting 4 speed input shaft
#535817
11/24/09 08:53 PM
11/24/09 08:53 PM
Posts: 4,084 Indiana
W5Duster436
Indiana
It appears I am going to have to take off about .500 from my trans input shaft to work with this crank. Is this something that any reputable machine shop should be able to do?
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
Re: Cutting 4 speed input shaft
[Re: W5Duster436]
#535823
11/24/09 09:46 PM
11/24/09 09:46 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
You can cut it with a cut-off wheel and dress it with an angle grinder when done.No big deal I had to cut my Richmond shaft because the Eagle cranks are not drilled deep enough(mine wasn't anyway) Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: RobX4406]
#535826
11/24/09 10:16 PM
11/24/09 10:16 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
No machine shop required. I've seen some that look like a drunk monkey cut them. Not even close to square and they ran fine.
Just dress/bevel the leading edge and you're fine
Agreed, "hicup" I did my own with cutoff wheel and grinder and all is well, does not need to be scienced out or that precise.
[Re: wheelsup68dart]
#535827
11/26/09 08:38 PM
11/26/09 08:38 PM
W5Duster436
Indiana
Well finally got out in the garage today after downing some turkey and stuck a dowel rod down to the crank and measured. It was exactly 9" to the back of the bellhousing and from the surface of the trans to the tip of the input shaft was a tad over 8 so there is enough space. Just can't figure out what could have been keeping it from going all the way in other than the adapter ring on the trans to fit the larger hole on the lakewood. Went right in the last time though..
[Re: W5Duster436]
#535828
11/27/09 01:39 AM
11/27/09 01:39 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Did the clutch maybe move? I had this happen to me once. I fought and fought with the trans on my chest trying to get it all the way in, it just wouldn't go. Finally after I was so angry I decided to check the alignment...... It was off by a hair... Trans went right in after that.....
