What's the current opinion on Ohio Crankshaft cranks? #535369
11/24/09 12:16 PM
11/24/09 12:16 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Depending upon when this question has been asked in the past, the opinion of Ohio Crankshaft's Mopar cranks have coverage the range from to .
So, what's the latest perspective, or - better yet - recent experience, w/ their cranks?
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: BradH] #535370
11/24/09 12:22 PM
11/24/09 12:22 PM
sg66mopar Offline
sg66mopar  Offline
Well, I have one in my 572. The short block's going in for a re-do here in a couple days. I'll let you know what my machinist says about the crank. It has about 200 hits right now.
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: BradH] #535371
11/24/09 12:53 PM
11/24/09 12:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Brad , Anything that is not a stock type 1053 forging should be good. Are you building a stroker or just getting that ticking bomb swapped out?
seriously , any of the low cost offshore forgings NOT finished machined here you should budget in getting it cut .01/.010 to take out the taper, you should NOT have to scrape a bearing , period .
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: JohnRR] #535372
11/24/09 01:32 PM
11/24/09 01:32 PM
BradH Offline OP
BradH  Offline OP
... Are you building a stroker or just getting that ticking bomb swapped out?
Common sense says I should simply plan to replace the OEM crank w/ a better 3.75" piece, since it's only a matter of time before it cracks.
The problem when looking at new cranks is that the INITIAL cost of a 3.75" part isn't any different than a 4.25"... It's only when you start to factor in the "butterfly effect" that the REAL cost of adding those extra cubes starts to become clear.
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: BradH] #535373
11/24/09 01:38 PM
11/24/09 01:38 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I have a Ohio 4.15 forged crank in my 499 Challenger. I have fun it for 2 full seasons running two classes a night and have around 600 passes on it. Will be pulling the motor this winter to check it all out. I am very happy with it and it needed zero extra work. Best e.t. is 6.01@112.25 in the 1/8th at 3300lbs.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: BradH] #535374
11/24/09 02:35 PM
11/24/09 02:35 PM
Brad, I have sold a lot of the Ohoi stroker cranks for Mopar BB motors that are mild to wild. No come backs yet I did ask them if they where Chinese imported forging that they(Ohio) finished and sold as "American" and they said absolutely not, all of thier forgings come from Ohoi Forge, 100% made in America the one thing I did find on the first batch I bought was the heat treating, they where a # 25 or 26 Rockwell when I had them tested. My crankshaft grinder thought that was a little soft and had me have them reheat treated I don't know what a good heat treat number is for a forged crank Maybe some one who knows will chime in with thier recomendations
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: Cab_Burge] #535375
11/24/09 02:49 PM
11/24/09 02:49 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I have an ohio 4.25 stroke, and i have a few friends that run ohio cranks as well. We all had them checked out and so far so good.
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: Harley] #535376
11/24/09 04:28 PM
11/24/09 04:28 PM
Joplin, Missouri
Mac's Hemi 64 Online content
Mac's Hemi 64  Online Content
Joplin, Missouri
I had my Ohio 4.25 purchased through Cab checked out by my brother. 35 years as a QC guy working on Jet engines. He Mag and X-rayed and said it was a better forging than most of the aircraft parts he worked on.
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: BradH] #535377
11/24/09 05:36 PM
11/24/09 05:36 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I have a 4.15 Ohio crank in my HEMI and so far so good.
The machinist liked it and he builds Pro/Mod motors!
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: BradH] #535378
11/24/09 06:02 PM
11/24/09 06:02 PM
AndyF Offline
AndyF  Offline
Call around and see what the professional engine builders are using. I'm always surprised when I make a few phone calls and hear what people have to say.
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: AndyF] #535379
11/24/09 07:15 PM
11/24/09 07:15 PM
gregsdart Offline
gregsdart  Offline
4.15 stroke, over 100 runs, 2432 bob weight, approximately 880 hp,7800 rpm. One very minor crack on dis-assembly, ground it out. Crank purchased back in 2002.
Re: What's the current opinion on Ohio Crankshaft crank [Re: gregsdart] #535380
11/24/09 10:12 PM
11/24/09 10:12 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
5 years on an Ohio 499" kit. Lots of miles and lots of passes, no problems. I'll buy my next kit from them.
Master, again and still
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: AndyF] #535381
11/24/09 10:23 PM
11/24/09 10:23 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I'd have to call you pretty experienced, Andy. What say you?
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: Cab_Burge] #535382
11/24/09 10:29 PM
11/24/09 10:29 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Cab i'm not trying to start any "discussion" if you know what i mean but imho there's NO way they're selling a american forged and machined crank for $600...just not happening. not that an import forging won't do the job (for many) and certainly surpass the oem piece if properly machined. i just don't see a 100% USA crank going for 25% of what others cost. of the imports i was under the impression eagle's stuff was "supposed" to be the best? obviously the leading problem with imports is the machining. i believe the callies compstar line is machined from imported forgings but they don't offer a bb chrysler crank.
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: BobR] #535383
11/24/09 10:34 PM
11/24/09 10:34 PM
AndyF Offline
AndyF  Offline
I don't have any experience with Ohio stuff myself. But I was a little surprised the other day when talking to a serious engine builder who was using Eagle cranks and rods in lots of builds. They said the stuff was working great for them. These are guys who make lots of power, not NAPA rebuilder type motors.
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: AndyF] #535384
11/24/09 11:00 PM
11/24/09 11:00 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
I bought a brand new Eagle crank and had to have it turned.
Re: What's the current opinion on Ohio Crankshaft cranks? [Re: AndyF] #535385
11/25/09 12:11 AM
11/25/09 12:11 AM
jamesc Offline
jamesc  Offline
i was thinking from what i've heard they're (eagle) probably being used in a lot more engines than people realize and as you mentioned we're not talking the "run of the mill" lower HP applications. i wonder how you could ever identify and/or find out exactly what forgings are coming from where as far as the imports and who's using them for cores. it might also be worth noting that as things develop overseas there is the potential that the quality of these pieces will improve. it seems like any other situation they have their differences in quality, ranging from "you really don't want this one" to "this will survive some noteworthy HP"
Re: What's the current opinion on Ohio Crankshaft crank [Re: jamesc] #535386
11/25/09 12:19 AM
11/25/09 12:19 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Don't you think the ohio crank, cat, eagle, 440 source, scat and other cheeper stroker kits basically are from the same forging place?
Re: What's the current opinion on Ohio Crankshaft crank [Re: rowin4] #535387
11/25/09 12:47 AM
11/25/09 12:47 AM
jamesc Offline
jamesc  Offline
possibly the same country but i would "think" like anywhere else there's different manufacturers forging them with different levels of quality...who knows, i for one sure don't
Re: What's the current opinion on Ohio Crankshaft crank [Re: jamesc] #535388
11/25/09 02:24 AM
11/25/09 02:24 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have not had any issues with the four I have used.
