Re: What starter to ask for?
[Re: juicedcuda]
#532505
11/21/09 05:16 PM
11/21/09 05:16 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
Does it sound like the starter is not engaging with flywheel? Or the gears inside the starter are junk?
it sounds like it isn't engaging with the flywheel and I just found out why, I got under the car and it broke a few of the ring gear teeth off the convertor.
HMMM....my converter was fine til I used a 440 source starter...then I mysteriously broke 4 teeth off the ring....had a new ring installed and bought one off of EBay and it works like a champ...
