Re: Some info on the RHS cast iron heads plus port work...
[Re: toddd]
#529448
11/18/09 05:27 PM
11/18/09 05:27 PM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
Adam...correct me if i'm wrong , but have a good look at the studs.......Let's leave that one where it is!
He got smart and went to LA shaft mounts on this set.
[Re: AdamR]
#529449
11/18/09 07:57 PM
11/18/09 07:57 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Great info, it will be interesting to see how they work in the car
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: S/ST 3040]
#529456
11/19/09 02:58 PM
11/19/09 02:58 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Thanks. Sorry for getting off topic.
Like I care....LOL
[Re: Brian Hafliger]
#529457
11/19/09 03:27 PM
11/19/09 03:27 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
thats interesting...
no issue with the 88mm stem and roller tip runout...
you could set the stands higher...no...? to get more keeper to rocker clearence.?.in the other sinario...
you put all new guides in? how long of a guide did they end up? finished length..?
is that the cut down intake valve..in the pic?
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: StrokerAspen]
#529460
11/20/09 12:20 AM
11/20/09 12:20 AM
Posts: 150 Illinois
fishy68
Illinois
Looking sweet Brian!! Can't wait to see the dyno report.
68 Cuda 408/904/8-3/4 02 Dakota 4.7 auto
#529461
11/20/09 10:30 AM
11/20/09 10:30 AM
Posts: 792 Earth
Rob C
Earth
Intake opening: Lets say at .550 lift air speed is 327fps!!
Wouldn't the intake, left stock, slow down the FPS rate?
