Re: comp 948 springs?
[Re: gregsdart]
#529030
11/19/09 09:57 PM
11/19/09 09:57 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Love my 948's. Ran K1000h's and they would break over winter sometimes. Mine in at 2.10.
The little old lady from Pasadena is back!
[Re: gregsdart]
#529033
11/20/09 11:02 AM
11/20/09 11:02 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Pardon my ignorance but what is the largest diameter valve spring you can use? Isn't the 948 a 1.650? I ask becuase if you can squeeze in a larger diameter it opens up more possibilities.
[Re: gregsdart]
#529034
11/20/09 11:57 AM
11/20/09 11:57 AM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
My dilemma is not being able to get a correct spring to fit with a 2.050 max installed height, yet still allow .850 net lift.
As much as I like Comp, I'd switch to a PAC spring. The PAC-1248 will handle a .900 lift easily. Its specs are: PAC-1248: 350 lbs @ 2.050, 950 lbs @ 1.20 This spring is spec'd to .900 lift
The PAC 1246 is a little less pressure and although this spring is spec'd to .800 lift, I have run them many times with .850 lifts with no problems. PAC-1246: 250 @ 2.050, 830 @ 1.20
[Re: Mopar_Rich]
#529035
11/20/09 01:08 PM
11/20/09 01:08 PM
Posts: 4,091 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Pieces like this (among others)makes the thread better...people adding their personal experience data. The post on YB was lengthly back and forth. I summed-up that unless your running specific parts with a spintron, laser and stress instrumentation, confidence in valvetrain dynamics comes from correctly evaluating experience(just like anything else I guess).
[Re: HardcoreB]
#529039
11/21/09 04:25 PM
11/21/09 04:25 PM
Posts: 1,664 North Sweden
RT540
North Sweden
My B1 heads came with PSI-1248 installed at 2.100"
DR1248,Triple,diam1.660",375lbs@2.100",1045lbs@1.200" coil bind 1.130"
Maybe PSI-1247 would fit at 2.050" installed height ? DR1247,Triple,1.660",340lbs@2.070",940lbs@1.270" coil bind 1.130"
[Re: Mopar_Rich]
#529040
11/21/09 07:26 PM
11/21/09 07:26 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
I don't agree. Here's the data from PAC. It shows an installed height of 2.1, but in this case the installed height would be 2.050. Even at .900 lift that puts the spring at 2.050 - .900 = 1.150, with stated coil bind not occurring until 1.130.
Rich, if you are really going to lift the valve .900, the installed height should be 2.15-2.2. Even then, you would have infinitesimal performance gain and a lot of heartache with anything short of a late 90's or later series PS head, IMO.
8.30's @3400 lbs
[Re: Mopar_Rich]
#529042
11/22/09 11:48 PM
11/22/09 11:48 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Thanks guys, I really appreciate the input. My choice is for a cost reason; I put so few runs on the car, the 948 would be my choice if I need them. I will check the 947 springs I have to make sure they are close to spec, and am starting the season with the same rocker ratio I have to keep things simple. I can install them at less than 2.00 and still have room. If i decide to go for this extra lift, the comp 948 springs can be installed at 2.050 and give me 355 seat pressure, and would allow a NET lift of .860 which is .050 more than my proposed change. As mentioned, a larger cam core might be needed, as I run a stock bearing sized cam, and lose a lot of lift just rolling it over on the stand. So not knowing enough about possible consequences at this point, I will wait to make my move.
