Re: Got myself an A100!
[Re: ]
#528122
03/18/11 11:44 PM
03/18/11 11:44 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Hey, that's MY place, not where I bought it! ![](/ubbthreads/images/graemlins/laugh2.gif) Paid a bit more than I hoped (over 1K), but it's a running driving /6 auto. Spent an hour or 2 tonight putting in angle shims on the front axle to get caster back. Also backed off the tight LF brake and adjusted the headlights. One dash bulb and the dome bulb out, everything else works. I haven't check the reverse lights yet. It's kinda fun to drive around, but I think I'm going to have to do something with the seats. They are a bit tall and I have to lean way back or scrunch to fit.
[Re: RodStRace]
#528123
03/19/11 03:58 AM
03/19/11 03:58 AM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
Congrats (I think) ![](/ubbthreads/images/graemlins/smile.gif) As long as you resist the temptation to turn this into a project, you should be good. Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: kick_the_reverb]
#528124
03/19/11 10:57 AM
03/19/11 10:57 AM
RodStRace
Chino Valley
Thanks, Ran. ![](/ubbthreads/images/graemlins/thumbs.gif) This will require a bit more work, but it's responding well to TLC so far. No big plans, just get it a bit more road worthy and comfortable. Maybe a bit of visual primping. It will also serve as a great example of how stuff goes back together!
[Re: Mopar Ron]
#528126
03/22/11 12:27 AM
03/22/11 12:27 AM
RodStRace
Chino Valley
Thanks Ron. This one is just a driver. ![](/ubbthreads/images/graemlins/biggrin.gif) Got it titled, registered and insured today and drove it to body shop class and back. Seems to have a top speed of ~55-65 MPH, depending on the grade. Drove well and it was fun to drive one instead of just beat the metal. ![](/ubbthreads/images/graemlins/laugh2.gif) I have a few things I'd like to do to it, but nothing major. Install a vent in place of the plywood covering the hole, swap out the thermostat and upper hose, fix the rear spring hangers and put blocks in to keep the height, add some curtains behind the seats and in the rear, and hope to find some panel side doors. Oh, and do something with the seats. They are bolted to the outside, but just resting on the doghouse on the inside ![](/ubbthreads/images/graemlins/eeek.gif) and too tall for me to drive comfortably, unless I lean waaay back! I may end up painting it at some point, but it will be a quick ![](/ubbthreads/images/graemlins/primer.gif) , not a full resto job. It's strange how the 108s do not have the character line behind the front doors. I may have noticed it before, but it didn't really sink in until I got this one.
[Re: RodStRace]
#528128
03/25/11 04:50 PM
03/25/11 04:50 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
WOW, I never noticed that before either. "interesting" ![](/ubbthreads/images/graemlins/coool.gif)
I have to stop looking at this thread, I find myself checking out vans for sale, to many other projects to finish ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: RodStRace]
#528131
03/27/11 03:55 PM
03/27/11 03:55 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
This is my first body work deal, I'm not as fast as your pros! Plus, I've been busy with the golf cart and bought another van. Hope to start back up on the 100 next week. Gotta put a sunroof in the 89 this week. It has big rust holes in the front roof ribs that leak. Rather than try to patch them up, I grabbed a sunroof so I can just cut out all the bad area. Will be at MATS, look for a Furious Fuchsia golf cart.
I CANT MAKE mats AGAIN THIS YEAR. Lets see the golf cart?
[Re: RodStRace]
#528134
04/28/11 05:33 PM
04/28/11 05:33 PM
Posts: 16,539 On the run…
BloFish
On the run…
Man am I glad I didn't have to go through any of that. Patience is a virtue huh?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#528135
04/29/11 01:20 AM
04/29/11 01:20 AM
RodStRace
Chino Valley
Patience is when welding all the gaps, grinding, then welding again, repeat a few more times.... and you still see a couple holes ![](/ubbthreads/images/graemlins/realmad.gif) Still have 3 more small patches and the other wheelwell ![](/ubbthreads/images/graemlins/weld.gif)
[Re: BloFish]
#528139
06/02/11 06:36 PM
06/02/11 06:36 PM
RodStRace
Chino Valley
Well, the summer school lab got cancelled (only 9 enrolled, needed 12), so I'll have to fiddle with it at home for now. Got the LF lower corner cut out of the parts PU to patch the van. Now I just need to get the PU shell back off the trailer and go get the van.
To update a couple things mentioned earlier, the sunroof didn't fit the 89 van, so it's still got holes in the roof. Shoulda measured... Got curtains in the 108 and took it to the local Mopar show. Also put in a cheap stereo. Will have to build a bracket for it, I don't wnat to cut the non-radio dash.
[Re: RodStRace]
#528141
07/19/11 12:56 AM
07/19/11 12:56 AM
RodStRace
Chino Valley
In keeping with using this post as a diary of the van and stuff in my life, I must post that my father died at 11:20 this morning. We are a small family, both my parents are only children and all the grandparents are dead. So now it's just my mom, my brother and me. My dad had Alzheimer's and his body held on long past his mind. He was dignosed fully back in 1995. He was always great about fitness and they expected him to last 1-2 years in 2005. I hate to loose him, but he was not there for years now. RIP Dad, I love you! ![](/ubbthreads/images/graemlins/engel016.gif) No need to comment, just needed to document. Thanks guys.
