Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527155
11/16/09 09:16 AM
11/16/09 09:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I had one do the same thing about 10 years ago. Mine had Childs & Albert rods. None broke, 4 bent. Stock block with aluminum caps. Never ran the motor over 6700 rpm. It had a Mopar 4.150 crank and Venolia pistons. Heres what I think happened. During the morning warm up on jackstands I could fell a very slight vibration but couldn't find anything unusual. I was making a pass and had him coverd so I lifted. It was then that I felt a big vibration. Looked in the mirror,no smoke. I though I broke a u_joint. I coasted around the shutdown. Not until I looked under did I see the hole in the block. During disassembly I discovered the crank broke in half at the front of the #3 main. It pulled both the #1 & #2 bulkheads out of the block. The rear half of the crank and rear 4 pistons were still intact. No bearing damage at all except the #3 main thrust where the crank broke. The block had had a freeze crack in the side ever since it was built. Moroso Ceramic Seal had sealed that crack. Aparantly it had also sealed any internal water jacket cracks. I think the block broke the crank.
Doug
Re: Friends 440 goes bang.... Carnage pics [Re: Cab_Burge] #527156
11/16/09 10:36 AM
11/16/09 10:36 AM
Tennessee
727builder Offline OP
Tennessee
1000 runs + , did he ever pull the oil pan and inspect the rod and main bearings as well as look for cracks in the main webs, if not this would be a good example of why you should look after 300 to 500 runs
It was planned to pull it out after this season to freshen. He has a 511 on the stand that was planned to go in for next season. The 1000 runs was a estimate on my part. 2 full years of racing every weekend. I Will have to go into his log books and count the passes.
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527157
11/19/09 12:03 PM
11/19/09 12:03 PM
NC
440Jim Offline
440Jim  Offline
NC
That is a ton of racing. I only put 150+ passes a year and I that is being a regular points racer. I know guys that race twice a week (basically) and they are around 300 passes a year, depending on how many rounds they win...
IMO, a stock crank is going to crack and eventually let go, and 1000 passes is way too many without a magnaflux. I think the flex hurts the block and eventually the crank breaks. But I could be wrong, the stock blocks do crack with good cranks too.
Re: Friends 440 goes bang.... Carnage pics [Re: 440Jim] #527158
11/19/09 01:48 PM
11/19/09 01:48 PM
Jarrettsville, MD
cudaman1967 Offline
cudaman1967  Offline
Jarrettsville, MD
I agree! It also had stock caps by looking at the photos
Cudaman1967 1967 Barracuda Turbo Outlaw 8.50
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527159
11/19/09 11:03 PM
11/19/09 11:03 PM
tampa florida
E
elephant express Offline
E
tampa florida
If you want to race now. I have a 440 with a ton of good parts. I guess it makes 600 hp. It ran 8:20's in a rail. $5000.00 complete. Carb to pan everything ready to run. KB pump,jesel belt drive,roller cam, rev kit,team G intake,roller rockers,Milodon swing pan,Dominator,cap, dist, wires,JW flex plate,after market rods,pistons and damper. It also has a set of I believe 906 heads ported by a guy on a NASCAR team. This motor always ran really good, My frends wife raced it one season and lost intrest. I haven't finished putting heads or pan back on I could send pictures before I put it all back together.
Thanks Joe
Re: Friends 440 goes bang.... Carnage pics [Re: elephant express] #527160
11/20/09 02:53 AM
11/20/09 02:53 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
It's fairly common knowledge the bb mopar will start to pull mains out. Once the support for the crank is gone the crank flexes and eventually lets go. Look for cap walk at the parting lines of the main caps. If there's metal transfer then the timer ended and the bomb went off...
