Re: Edelbrock STR-14
[Re: kruger]
#526915
11/17/09 11:21 PM
11/17/09 11:21 PM
Posts: 659 Tampa Fl
kens avenger
mopar addict
mopar addict
Tampa Fl
This was in the back of a old car i bought years ago..6BBL top
Can get better pic's if wanted
Remember in here some don't think you should have a Opinion.. sad fact..
[Re: Bishop]
#526917
11/18/09 06:02 PM
11/18/09 06:02 PM
Posts: 428 wappinger falls new york
Jimi_Vignogna
Just like at the beginning of the thread I have a single 4BBL STR-14 I'm planning on making a 2 -4BBL crossram top. My Question is should the 2 Alum. carb spacers have one big hole or 4 smaller holes thru the top plate, which one will perform better? Brian
buy hvh super suckers,only buy aluminum, the plastic ones burn on the edges
[Re: GTSDave]
#526920
11/18/09 08:15 PM
11/18/09 08:15 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
guys, if anyone needs anything made, you will not find a better person to deal with than Jerry. he has made a few things over the years for me and reasonable ![](/ubbthreads/images/graemlins/Twocents.gif) he made this fuel log ![](http://i40.photobucket.com/albums/e225/sixpackgut/835117919_l.jpg) he did an incredable job on this intake ![](http://i40.photobucket.com/albums/e225/sixpackgut/IMAG0045.jpg) made the lid on this one ![](http://i40.photobucket.com/albums/e225/sixpackgut/mopartspicture.jpg) and another fuel log that is still on my car. ![](/ubbthreads/images/graemlins/thumbs.gif)
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: GTSDave]
#526921
11/19/09 12:31 AM
11/19/09 12:31 AM
Posts: 1,031 South Jersey
kruger
Yours Too!
Yours Too!
South Jersey
That's My Intake and I have modified it even more. Damon is a great friend of mine and does know his STR's. He Has been deep into the 9's with less than 500" in Fugly.
http://www.fugly-racing.com/
-Dave
He did a great job modding my STR Crossram.Damon knows his stuff for sure.
GTSDave,did you have to do any blending in the intake area underneath the top plate wheres the carbs mount?
[Re: kruger]
#526922
11/19/09 01:17 AM
11/19/09 01:17 AM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Yes, but not very much, just a gentle blend in those two corners to clean up some of the machining they did when they moved the two carbs in-line. There isn't a whole lotta meat there to work with, but there is enough for what I needed.
In NSS I must run Eddy carbs, and I have a pair of Diamondback NSS ones set up for my 4-Speed. For now this is the best intake/carb combo for a low deck running in NSS classes.
The in-line mod that was done to mine was pretty slick, but because of the spacing needed between the two carbs, there isn't much room on those two corners. I bought it with that top plate already done.
They basically plugged the two cross ram carb holes, then machined a big path down the middle and welded in the plate you see in the pics. It is VERY strong and doesn't lend itself to cracking like many of the factory in-line 2x4 setups. Those intakes were pretty thin through the carb area and were prone to cracking.
We have done a couple more mods to the top plate to make it more user/carb friendly and I will run it that way until something better comes along. Damon does a great job with his cams for this setup and I am running one of his profiles. My engine is less than 500" as well. It should be a screamer.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: BBLM23]
#526925
11/19/09 08:34 PM
11/19/09 08:34 PM
kruger
Yours Too!
Yours Too!
South Jersey
That's My Intake and I have modified it even more... -Dave
I got that intake from Lou and Jimi V.
Were they running that intake on one of there Super Stock cars? I'd like to get a peek inside that intake any pics? ![](/ubbthreads/images/graemlins/drool5.gif)
[Re: kens avenger]
#526926
01/06/10 12:01 PM
01/06/10 12:01 PM
Posts: 434 sweden
cuda-sweden
sweden
yes please post more pics,could you please post pics of the underside of the lid.they never made a six-pack top for str-15?,or did they.dont think so,so im going to make my own str-15 sixpack top and would love pictures of the str-14,and pictures inside the bottom to,i think the dc bible refers to a rib in the front middle,maybe there are someone witch has done more mods that want to share some info,no ![](/ubbthreads/images/graemlins/XmasPeng.gif)
[Re: Bishop]
#526929
03/28/10 02:46 PM
03/28/10 02:46 PM
Jimi_Vignogna
I finally got my crossram top made using a 1/2" plate and using 1" carb spacers. I want to Thank everyone that gave me help and advise. We'll see how it works now.
Brian
nice job! did you raise the top up at all? the couple i have modified liked a 1 inch spacer.
[Re: Bishop]
#526930
03/28/10 03:25 PM
03/28/10 03:25 PM
Brian
if you could get a piece of thick pvc material to space it like a sandwich you'll make more power, keeping the top from the heat. it acts like a thermal barrier.
