Anyone here using a Stacker Trailer? #523078
11/11/09 01:55 AM
11/11/09 01:55 AM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Like it says in the title. Is anyone here towing a stacker? If so what brand and length, and what are you towing it with. We are looking at maybe buying a stacker in the not to distant future, any pros and cons? Any input is appreciated.
Re: Anyone here using a Stacker Trailer? [Re: Al_Alguire] #523079
11/11/09 02:27 AM
11/11/09 02:27 AM
Arizona
Chris'sBarracuda Offline
Happy Birthday Chris'sBarracuda  Offline
Arizona
I'm interested too...
I've been thinking about going that way for awhile now..
Happy B-Day though..
Chris..
Re: Anyone here using a Stacker Trailer? [Re: Al_Alguire] #523080
11/11/09 02:46 AM
11/11/09 02:46 AM
Mazzolini has(had?) one for sale, call him and ask him what he thinks about them
Post deleted by Defbob [Re: Chris'sBarracuda] #523081
11/11/09 02:52 AM
11/11/09 02:52 AM
Re: Anyone here using a Stacker Trailer? #523082
11/11/09 07:01 AM
11/11/09 07:01 AM
Indiana
79_W200 Offline
79_W200  Offline
Indiana
Stay away from the Renegade brand. I work on primally race trailers. I see alot of the Renegade trailers broken do to lack of quality and not built strong enough, the featherlite seems to be good quality usually only replace worn out tires or brakes.
1979 W200 470
Re: Anyone here using a Stacker Trailer? [Re: Al_Alguire] #523083
11/11/09 07:47 AM
11/11/09 07:47 AM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
There are two types of trailers called "stackers"; those that lift the car once the car is inside the trailer and (2) those that lift the car using the rear door.
In terms of longivity, the type with the lift door are the best but also the most expensive and require the most maintenance. Why? The design requires the "second" floor where the cars ride to be a structural floor, this makes the trailer to be far more rigid. The rear door is either hydraulic or screw type lift----both types require maintenance(cleaning/greasing) on a periodic basis. This type of trailer is usually heavier, requires more tractor to pull/stop, etc.
The trailer that lifts the car once inside the trailer is really nothing more than a tall "regular" trailer with a lift insalled inside----often nothing more that a commercial four post lift. They are far cheaper to buy, are much lighter in weight but also are not nearly as strong. We have followed many of these trailers on the road and watched the trailer flex with every bump. Even though the trailers are tall, most can be towed with a heavy one ton dually safely. As a point of comparison, most Renegades are this type of trailer.
We own neither type of trailer---although we saw both types at every race we ran in our former life as dirt late model racers---and know plenty of owners. The trailer we own is a 5150, built by a local company----their web site is www.5150racetrailers.com. They are very strong in dirt late models, tractor pullers and just beginning to get into drag racing----they have supplied the Pedegron brothers and have Ron Capps under construction now. I like them for their appearance and custom extruded trim----they also custom build each trailer on a jig plate.
Re: Anyone here using a Stacker Trailer? [Re: 40ford] #523084
11/11/09 09:25 AM
11/11/09 09:25 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My buddy used to have one.Hiw was gigantic.He was towing with a 3500 Ram and it looked like a tinker toy when it was hooke up.He liked the way it towed but went with a totter.Rocky
Chrysler Firepower
Re: Anyone here using a Stacker Trailer? [Re: Al_Alguire] #523085
11/11/09 09:31 AM
11/11/09 09:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Too much frontal surface area for me... too much
drag (wind resistance and kills the MPG)
Re: Anyone here using a Stacker Trailer? [Re: MR_P_BODY] #523086
11/11/09 10:50 AM
11/11/09 10:50 AM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
When you get into the tall trailers, oftentimes the one ton trucks suffer fuel mileagewise, 6-7 MPG becomes common. We went on a 940 mile trip recently with our Freightliner 70 "Toter" pulling a loaded 36" gooseneck(11'6" tall) and averaged 11.3 MPG. The "Toters" just get better mileage pulling the tall trailers.
Re: Anyone here using a Stacker Trailer? [Re: 79_W200] #523087
11/11/09 11:26 AM
11/11/09 11:26 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've never saw a Renagade product that I liked.
Post deleted by Defbob [Re: MR_P_BODY] #523088
11/11/09 11:31 AM
11/11/09 11:31 AM
Re: Anyone here using a Stacker Trailer? #523089
11/11/09 11:35 AM
11/11/09 11:35 AM
Las Vegas
Las Vegas
No duallie here, well I still have one. However we have purchased an adequate tow rig for the job. Now looking at ways to get two cars to the track together.
Re: Anyone here using a Stacker Trailer? [Re: Al_Alguire] #523090
11/11/09 11:44 AM
11/11/09 11:44 AM
Lehigh Acres, Florida
rickstershemi Offline
T&E None Better
Rickster
Re: Anyone here using a Stacker Trailer? [Re: rickstershemi] #523091
11/11/09 12:05 PM
11/11/09 12:05 PM
Cincinnati, Ohio
Cincinnati, Ohio
T&E None Better
Rickster
One of the best for sure, Gold Rush and Champion are right up there too.
Re: Anyone here using a Stacker Trailer? [Re: Al_Alguire] #523092
11/11/09 12:37 PM
11/11/09 12:37 PM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
Seems like I find more things to say----There are two basic way that trailers are assembled:
1. The base is welded together, then the sides and roof are usually riveted to the base. Using this method, all the stresses are on the base and the sides aren't really "load bearing". This requires a much heavier base frame---more weight.
2. The base and sides are "load bearing" and are welded as a unit. The top is usually welded on as a unit as well. This results in a lighter trailer with the same load bearing strength. It also produces less flex going down the highway.
Re: Anyone here using a Stacker Trailer? [Re: 40ford] #523093
11/11/09 01:25 PM
11/11/09 01:25 PM
Cincinnati, Ohio
Cincinnati, Ohio
Gold Rush, All welded aluminum.
Re: Anyone here using a Stacker Trailer? [Re: Challenger 1] #523094
11/11/09 02:58 PM
11/11/09 02:58 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Al - a few things:
1) Happy Birthday
2) Two cars to the track at the same time? Hmmm...
3) If Mazzolini has one for sale - I'm in riverside right now and can swing by and take a look at it.
Let me know.
Re: Anyone here using a Stacker Trailer? [Re: Lil Demon] #523095
11/11/09 03:06 PM
11/11/09 03:06 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Call and speak to Ronnie @
www.performaxtrailers.com
He will provide sound advice, made right here in DFW
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Anyone here using a Stacker Trailer? [Re: Al_Alguire] #523096
11/11/09 03:53 PM
11/11/09 03:53 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
Just remeber you will have to plan you're trip well, as alot of older under passes wont fit a stacker trailer.
Re: Anyone here using a Stacker Trailer? [Re: Sub95] #523097
11/11/09 06:49 PM
11/11/09 06:49 PM
NE Ohio
MaxWedge65 Offline
MaxWedge65  Offline
NE Ohio
Storm makes a nice one. I have attached a picture of one recently completed. Give me a call and we will price one out.
Scott O'Dell Moparts Username: MaxWedge65 Victory Trailer N. Lawrence, OH 44666 Ph. 330-705-5727 Fax: 330-837-0810 Email: Scott@VictoryTrailer.com Website: www.victorytrailer.com
