Re: Mini Tub Dart and Scamp ?? [Re: moparniac] #521757
11/10/09 06:48 PM
11/10/09 06:48 PM
Utah
dragnduster Offline
dragnduster  Offline
Utah
Thanks for the pics 540DART, looks like quite a nice car.
Re: Mini Tub Dart and Scamp ?? [Re: dragnduster] #521758
11/10/09 06:58 PM
11/10/09 06:58 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Here is 1 more
I like the low tucked look.....
Mopar Performance
Re: Mini Tub Dart and Scamp ?? [Re: moparniac] #521759
11/10/09 07:25 PM
11/10/09 07:25 PM
Utah
dragnduster Offline
dragnduster  Offline
Utah
Here is 1 more
Yea, the motors not to shabby either
Re: Mini Tub Dart and Scamp ?? [Re: moparniac] #521760
11/10/09 08:20 PM
11/10/09 08:20 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Tires are 13 5/8th wide on 10" rim 315/60/15..... 3 3/8 backspacing good inch clearance on both sides... spring boxes inside of framerail. wheelwell lips rolled some .... I may roll the fronts a hair as they havnt been touched and rear in stock location,,,,
That 1 of the tires I want to run. If you have an inch clearance on both side I should have no problem moving the tub to the frame rail spot weld edge instead of the frame.
Re: Mini Tub Dart and Scamp ?? [Re: BEEQUIK] #521761
11/10/09 09:37 PM
11/10/09 09:37 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
my 68 dart had 30x13.50 ET Streets on it. It was mini-tubbed but used an aftermarket tub not the factory one.Also the qtrs were stretched 3"
What size tubs did you go with and do you have any pics inside the trunk?
Love that look
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
