Page 44 of 127 1 2 42 43 44 45 46 126 127
Re: 440 trucks [Re: MachoMan] #5208
02/24/05 12:17 PM
02/24/05 12:17 PM
I only had one experience in flying that was a little odd, and that was that we landed in Minneapolis, and on the approach you could feel the plane feathering from side to side to slow down, and then, a sudden burst from the engines right before touchdown. We landed really hard and everyone onboard just got real quiet.. . Was fun though. I love flying, and would not hesitate to jump onboard another plane. I almost went skydiving once, but my mother of all people talked me out of it..
Re: 440 trucks #5209
02/25/05 01:46 AM
02/25/05 01:46 AM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
should have my motor back by next weekend oh boy,,,oh boy,,,I cant wait
Re: 440 trucks [Re: smokn440] #5210
02/25/05 01:40 PM
02/25/05 01:40 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
Alright Joe, that didn't take long!!
Re: 440 trucks [Re: 70Challengerse] #5211
02/25/05 09:09 PM
02/25/05 09:09 PM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
well,,,,the keyword is "should"...we'll see what happens
Re: 440 trucks [Re: smokn440] #5212
02/25/05 10:23 PM
02/25/05 10:23 PM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
That's great . So what all did your machine shop end up doing to your engine?
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: 440 trucks [Re: adventurer] #5213
02/27/05 12:50 PM
02/27/05 12:50 PM
Joe where are you?
Re: 440 trucks [Re: 70Challengerse] #5214
02/27/05 02:20 PM
02/27/05 02:20 PM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
In Hawaii just having a super busy weekend,,,going 30 over on the bore,,,new pistons,,rings,,cam,,oil pump,,,the usual bottom end rebuild,,,,freshened up heads,,,valve job,,,and I had em put it all back together,,,I just have to put water pump and intake on,,,,so now i gotta get out there and clean up water pump today,,,,lucky for me its pourin rain and saved me from yard work today
Re: 440 trucks [Re: Fargo Freek] #5215
02/27/05 02:45 PM
02/27/05 02:45 PM
ME
79machocharger Offline
ME
Im also leaving for mexico in two weeks. Im going to coco beach by playa del Carmen. Im not looking forward to the flight either. Flying from maine to Cancun is going to be a long flight. I plain on having a few drinks on the flight and having a lot more when i land in cancun.
Re: 440 trucks [Re: 79machocharger] #5216
02/27/05 02:55 PM
02/27/05 02:55 PM
in my case,there would be a he!! of a lot of drinking before,just have to hold it together,so they let you on the plane.
Re: 440 trucks [Re: 70Challengerse] #5217
02/28/05 03:03 PM
02/28/05 03:03 PM
I think you should give flying a try, If you like speed it is a rush on takeoff.
Re: 440 trucks [Re: smokn440] #5218
03/01/05 12:29 AM
03/01/05 12:29 AM
adventurer Offline
adventurer  Offline
So what did you end up choosing on cams? A few tips on the new engine that you may or maynot know to do, be sure you prime the engines oil system before ever firing it up. Get all those oil galley full of oil. Dry start is one of the most common new engine failures. Also don't add any of those oil additives they can keep your new rings from seating. I know you have your engine bay all ready so you won't be doing this but don't leave a freshly built engine setting for too long before starting. A month or so won't hurt but if its going to be longer be sure you turn the engine over periodicly by hand to keep everything free. Also another startup problem is having the coolant system not completly bleed of air before firing. If there is trapped air in the radiator system the engine temp will got out the roof real quick. That happen to me when I first fired my engine up. And one last thing and I'll quit preaching be sure to follow breakin procedures on your camshaft after the engine is fired up. Most hyd. cams need to be "run in" when first fired up. You do this by getting the engine running first, make sure you have no major leaks and then run the engine at 1500/2000 rpm for about 15/20 minutes. This hardens the cam & lifters to one another. Your machine shop will probably tell you all this but just in case. Good Luck with the new engine
14 Ram R/T
Re: 440 trucks [Re: adventurer] #5219
03/04/05 11:39 PM
03/04/05 11:39 PM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
let the fun begin
Re: 440 trucks [Re: smokn440] #5220
03/05/05 02:45 AM
03/05/05 02:45 AM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
that's PURDY!!!!
let the fun begin
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: 440 trucks [Re: smokn440] #5221
03/05/05 09:02 AM
03/05/05 09:02 AM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
that thing'll never run w/o a carb/intake.
Please register your Dodge truck here 1972-1980 Dodge truck registry
Re: 440 trucks [Re: smokn440] #5222
03/05/05 01:42 PM
03/05/05 01:42 PM
Upper left hand side on the valve cover,did you forget to shake the can. looking good Joe!!
Re: 440 trucks [Re: 70Challengerse] #5223
03/09/05 03:23 AM
03/09/05 03:23 AM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
motors in,,,only a few things left to throw on,,,WILL be runnin this weekend
Re: 440 trucks [Re: smokn440] #5224
03/09/05 01:23 PM
03/09/05 01:23 PM
Rosedale B.C Canada.. Eh
Fargo Freek Offline
super gas
Fargo Freek  Offline
super gas
Oh Boy Joe Now I am getting excited ( LOLOL) it,s looking gooooooooood man keep up the good work
I was the Black Warlock but now Iam the Fargo Freek 1950 plymouth fast back (custom) 1951 Fargo spring special 1996 Dodge 1500 Pu 2008 Magnum AWD The way I see it is If It doesn,t say MOPAR then what else is there. E Mail me @ nascar2000@telus.net
Re: 440 trucks [Re: smokn440] #5225
03/09/05 01:58 PM
03/09/05 01:58 PM
Looking good Joe, keep the pic's coming...
Re: 440 trucks [Re: 70Challengerse] #5226
03/09/05 02:11 PM
03/09/05 02:11 PM
dynotune440 Offline
dynotune440  Offline
gotta get some battery cables! Lookin good!!!
Re: 440 trucks [Re: dynotune440] #5227
03/09/05 08:18 PM
03/09/05 08:18 PM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
now that's what i'm talking about.
that's starting to look as good as ric's.
very nice.
